Oppo BDP83-SE : my first impressions
Posted by: Dungassin on 07 February 2010
I've finally got the Oppo 83SE bedded in and now feel happy to make some comments about it.
Rather clunky fast forward/reverse. Not nice to use.
Analogue outputs - eventually got it sorted out. I must have mislabelled one end of my analogue leads, as I had to reverse V1/V2 at the AV2 end. 8-P
Incidentally, using a sound meter, the subwoofer output level setting on the analogue outputs is the same as that for the coaxial digital - which is different from your findings, Tony. Playing bluray discs via the analogue output, the subwoofer output is well integrated, so I believe I have set the levels correctly.
Bluray HD audio (PCM, Dolby TrueHD, DTS master) all better than the downgraded version via the coaxial digital output. I would rate it as a little more obvious than going from 128bit MP3 to WAV.
DD and DTS (not HD) I find preferable via the coaxial digital lead into my AV2 rather than using the Oppo's analogue output. A testament to the quality of DAC implementation in the AV2Cool
Bluray picture - not much different from that from my PS3 (now in the hands of my son-in-law). I'm only using a 40" 1080p display, so daw your own conclusions.
DVD picture - a little better than from my DVD5, but this may be down to the Oppo upscaling better than my Sony TV does.
DVD-A = less capable than the Naim DVD5. Using the DVD5 I preferred the multichannel DVD-A to CD, but with the Oppo, although DVD-A is good, I prefer the DVD5 playing the same tracks on CD. I have set up the DVD5 with all the video outputs disabled, and it does run direct into the NAC282 via HiLine, so it may not be a fair comparison (damned if I'm going to disconnect everything to try ordinary DIN into the AV2!)
SACD - On the Oppo itself, to be honest I couldn't really tell any difference betweed CD and stereo SACD via the analogue outputs (you can switch which version you listen to on the Oppo in the setup menu). However, I did prefer multichannel SACD to stereo SACD. The DVD5 (CD, of course!) easily outperformed the Oppo, and had much more of that toe-tapping quality. Can't see myself going out of my way to buy any more SACDs.
I've reprogrammed my Harmony remote to work well with the revised setup, and in the Oppo "activity" have set a couple of buttons to let me easily switch between coaxial digital and "multi" inputs on the AV2.
The sound quality on the supplied AIX bluray calibration/sampler is very pleasing.
On the whole, a worthwhile purchase, but I can't comment on whether the 83SE is better than the ordinary 83, never having heard/seen the latter.
Now all I've got to do is persuade SWMBO to let me replace the DVD5 with something like a CDX2.2 ... 8-)
Posted on: 07 February 2010 by tonym
Thanks for your comprehensive and interesting report John.
I've yet to read a true comparison between the SE and the standard model; I'm pretty pleased with the analogue HD output of mine so for the time being I'm not going to lash out the few hundred quid for an upgrade.
I certainly agree with you regarding the high quality of the AV2's SP/DIF decoding prowess.
Posted on: 03 March 2010 by sparx
which unit would you use for reg. DVD ? DVD5 or BDP83-SE?
sparx
Posted on: 04 March 2010 by DAVOhorn
I borrowed the BDP 83 SE with the Terra Firma clock.
Against my modded Orelle CD 100 it was better in most areas eg bass definition information retrieval vocals and top end. It only lost out on timing and musicality. Also it plays all my discs.
Against my SONY SCD 777 es SACD player it was pretty close on both CD and SACD, which is a bit worrying. Then my SONY started to play up and mis read discs and not read discs and say no disc after reading disc. Seems the SONY is dying either laser or transport or both.
For the money the OPPO is pretty damned good.
Will look at getting SONY fixed but the laser is 90 quid if you can find one. And then if that is not the problem it seems transport bearings and spindle and sled mechanism could be shot!!!! the joy of old high value HIFI from a major couldnt give a f*&k its over 5 years old manufacturer.
Going onto DIY audio and stereonet reveals it shouldnt have lasted this long. HO HUM.
i shall go off and cry,
david
Posted on: 04 March 2010 by Dungassin
Hide Post
Well, I'm no longer using my DVD5 for DVD playback. In my setup the Oppo/Sony TV combination gives a better picture than the DVD5/Sony TV combo. May be down to the Oppo having a better upscaler than the Sony TV - remember that the DVD5 does not have an upscaler built in.
As regards sound on DVD - well, digital is digital and I am perfectly happy with the sound of the Oppo's digital output into the Naim AV2.
Posted on: 04 April 2010 by Paul Russell
The Oppo BD-83 (and the discontinued DVD-only DV-983H) uses the Anchor Bay upscaling chips, widely regarded as being the best upscaling sub-system available.
Paul.
Posted on: 28 April 2010 by Occean
John
I am curious, now you have had the Oppo a few months, how are you finding it? Still a satisfying upgrade from the PS3
I am seriously considering buying one very shortly...I really want to move to HD sound. Also which cables did you use, naim or 3rd party?
I too currently use a AV2, Ps3 and 40" screen.
Posted on: 28 April 2010 by Dungassin
God! Has it been that long? Well ...
I'm still very happy with the Oppo. I'm using it with Chord Crimson cables. It (like the DVD5) occasionally throws a wobbler, which means disconnecting it from the mains, but otherwise functioning fine. I still think the "fast forward" is rather clunky, but the picture and sound quality are excellent.
To be honest, the picture isn't a lot better than the PS3, but that may be down to the limitations of my display. Can't comment on its HD sound via HDMI, as, of course, the AV2 doesn't support that. However, the HD sound via its analogue outputs into the AV2 is a worthwhile acquisition.
Also, I can't comment as to whether its analogue sound is better than the standard Oppo 83, never having done the comparison.
DVD5 totally relegated to use as CD player. Still debating (SWMBO permitting) whether to get a Naim DAC for it, or change it for a CDX2.2
Winker
Posted on: 29 April 2010 by Occean
Cheers...order placed.
Posted on: 29 April 2010 by Dungassin
Hope you like your Oppo when it comes.
Just looked at my last posting here. Boy, did I really cock up the quoting. Must have caught that stupid mouse pad on my laptop while typing and moved the cursor.
Eek
Posted on: 29 April 2010 by Vaughn3D
My friend purchased an 83se and I had the opportunity to use it at home for a day, you'll likely be very happy with it. I could not see or hear any difference from my Cambridge 650bd.
Posted on: 29 April 2010 by nap-ster
That's a bit worrying.
why would that be worrying? The two machines are priced within $200 of each other. It's not like one is twice the price of the other....
Two things:
1. The 83SE has the upgraded analogue board.
2. The 83/83SE has the Anchor Bay processor.
Posted on: 29 April 2010 by js
Tried it as a CD transport. Meh. Didn't use a DVD/BluRay player but I suspect it's much better at this.
I believe the 650bd is the same hardware as the oppo BD-80 which is two models lower.
I don't think the 650bd is a clone of the BD-80 (I certainly hope not). I recently saw the following post on another site and wanted to communicate it. I hope I'm not violating any rules by pasting this here:
The forthcoming Cambridge Audio 650BD is based on the Mediatek MTK8520/MTK8575 chipset. Cambridge Audio of course have a long relationship with Mediatek having based our DVD89/99, DV30 and 540D V1 and V2 DVD players on various Mediatek platforms.
When we decided to enter the Blu-ray market we did in fact investigate several alternatives but the sophistication and performance of the Mediatek platform made it a natural choice. As you would expect we are not the only brand to be using Mediatek development kits and application software, Oppo being the most well known other brand. Actually generally brands like us prefer to use platforms that are also used by other customers as it means that when/if issues with discs and playback formats are found everyone is feeding back into a common knowledge pool (Mediatek in this case) and all brands benefit in terms of the reliability and robustness of the chipset.
In terms of what Mediatek offer each customer the processor includes an OSD generator and tools for defining setup menus and the like. In fact Mediatek supply application code that gives an excellent framework for this. This does of course mean that any machine based on the chipset is very likely to have a similar look and feel to the On-Screen Display.
Ditto the connectors can be similar as there are various guidelines and designs included for PCB layout. Each manufacturer then edits these to greater or lesser extent to add their own flavour of sockets, DACs, power supplies etc. as they see fit.
So, in short, CA and Oppo or others actually have no relation. We are merely connected by our relationship with the actual chipset supplier, Mediatek.
James Johnson-Flint
CEO, Cambridge Audio Ltd / Audio Partnership Plc
Was that using the analogue outputs on both?
yes, analogue on both. Coax digital into the Supernait from the Cambridge put a bit more emphasis on the midrange and was more lively. I did not try the Oppo as a transport.
