Earthing Dedicated Mains Spur
Posted by: kelty on 19 June 2008
Hi,
I'm going to wire three adjacent double sockets together tomorrow as a spur and then get electrician to connect at existing CU. Could somebody please explain how to connect the earth at the 3 sockets to the spur? Do I connect the spur earth to the first or last socket and then daisy chain the earth?
Your help would be much appreciated.
Thanks, Nigel
Thanks, Nigel
Posted on: 19 June 2008 by Guido Fawkes
Sorry I don't think we are allowed to discuss such topics on this forum. Just in case the advice is wrong and you get a nasty shock.
The usual way to get Naim kit sorted is to use a Hydra in to a single spur installed by a qualified electrician, but I think the advent of the Power-Line may have moved that on a bit.
ATB Rotf
ATB Rotf
I think you will find this is in the wrong room. This should be in the Padded Cell.
munch - I don't think we allowed to go as far as Nigel needs because he's asking specifics about wiring sockets (I'm sure Adam will advise). There are audio DIY forums that could answer if you go fishing for them in a pink suit.
ATB Rotf (no post yet
Posted on: 19 June 2008 by kelty
Thanks for your replies - not sure if I fully understand them. If it helps - I was obviously going to get my electrician to check my socket wiring when he connects to CU. I think this takes it out of DIY electrical work realm but if a problem then I will just guess what to do - is that a healthier position for everyone!? I was only doing the socket end as I need to check some bad floorboards under stairs where hi-fi is tomorrow and it would be cheaper if I get this bit done myself. Hey ho!! Thanks anyway. Nigel
Posted on: 19 June 2008 by 555
Thanks 555 for your inspired contribution. It appears that you think I should be in a padded cell but not in this forum. I continue to live and learn! N
If you need to ask you shouldn't do it Nigel.
Oh yeah - I was trying some new smilies Adam sold me
These are really good Adam!
As I said I would have got an electrician to check what I was going to do - and I meant that seriously. I am fully aware of the dangers of electricity and agree with the new regulations. I just found your "smilie" a little patronising. But, just to make sure I know I was being patronised you gave your last comment. Thanks. N
Posted on: 19 June 2008 by djftw
I don't know about that, my best friend is a sparky and even he admits that some of the new regs are pathetic. Something along the lines of, if you can't change a light fitting on your own you shouldn't be trusted to drive as it is far more difficult! Not that he minds, more business for him!
quote:As I said ...
Welcome to the forum
Another forum member with a humour bypass - Excellent!
Posted on: 19 June 2008 by manicatel
N.
Oh, by the way
Matt.
Oh, by the way
Matt.
quote:if you can't change a light fitting on your own you shouldn't be trusted to drive as it is far more difficult! Not that he minds, more business for him!
change a light fitting?
Until I got one of things that switches on the lights when it gets dark, I used to call an electrician to turn the lights on each night
