V8 vs V12
Posted by: Tony Lockhart on 06 January 2004
I have some Evans vouchers burning a hole in my pocket, and I fancy changing the pedals on my Trek 4500. Apart from price and sealed bearings, are there any other differences between these two from DMR?
Tony
Posted on: 06 January 2004 by Former member
Tony,
V12 = V8 + cartridge bearings (thus smoother and stronger)+ better seals, so less maintenance and more reliable.
HTH
Robin
Posted on: 07 January 2004 by Tony Lockhart
Robin,
Thanks, that'll do me.
Tony
Posted on: 07 January 2004 by Mekon
I used to ride BMX with the guys that run DMR back in 1996. It was run out of a side room off a tiny BMX shop on an industrial estate on the edge of an old quarry back then, but they used to have some crazy stuff. Among other things, Dom used to have a full sus BMX that he'd put together when he was designing stuff for other people. I tried to do a 12 foot step up on it, and it being the first time I'd ridden a full sus, if forgot to preload. I smacked into the lip of the landing, tried to 180 out of it, but the transition was so tight, I ended up faceplanting. Grim.
