Clear drag and drop items, on OSX.
Posted by: BigH47 on 18 April 2009
I'm having trouble selecting items by "ctl" click then copy. Instead of over writing previous item it seems to add the latest one, to the previous one, as regards photo locations.
Is there a way to empty what was in the copy carrier thingy?
I think it was a setting on photobucket that was wrong.
Although the reset/empty thing might be useful to know.
Posted on: 19 April 2009 by garyi
Eh?
Pressing control whilst dragging will create a copy, just don't press control.
Sorry your post does not make a lot of sense.
Posted on: 19 April 2009 by BigH47
I couldn't copy and drag anything new, it kept putting the same unwanted item into the image link in the dialogue box.
I think it was photobucket settings not actually allowing the copy to over write the previous item.
This is not easy to describe.
Sounds like an imageshack problem I guess, can you recreate the problem elsewhere.
