Can PCs give harmful radiation?
Posted by: max in hampshire on 09 February 2004
Hi
I bought a new pc in September. Since then on three occasions I have experienced considerable numbness in the side of my face. Medical exploration of the problem has not revealed a possible cause. I have recently realised that each time the problem has followed a session of 6 hours or more using the pc. Does anyone know whether potentially it could be radiation of some kind from the pc?
I have a 19 inch CRT monitor and a 2.6 Athlon processor I guess these would be the only possible causes of the problem. The computer is very noisy, as I mentioned in a previous thread and with regard to which Evesham are sending and engineer next week. But I expect this is purely due to cheap fans.
Anyone have any ideas on this.
Max
Posted on: 09 February 2004 by Andrew L. Weekes
Max,
I would be VERY surprised if your PC, or it's monitor were the cause, in terms of emissions, anyway.
Far more likely is a posture / ergonomics issue.
For more information on Exposure to Static and Time-varying electromagnetic fields, the National Radiological Protection Board issues guidelines in the UK: -
http://www.nrpb.org/radiation_topics/emf/index.htm
There is no specific legislation limiting exposure to non-ionizing electromagnetic fields in the UK, but there is enabling legislation in the form of Acts of Parliament affecting Health and Safety. Such legislation includes the Health and Safety at Work etc Act 1974 and the Management of Health and Safety at Work Regulations 1999.
The above safety legislation is general in its scope in that it does not explicitly mention EMF’s, however inspectors from the Health and Safety Executive accept compliance with the NRPB guidelines as evidence that exposure to EMF’s has been adequately controlled, see HSE link below for more information: -
http://www.hse.gov.uk/radiation/index.htm
Unless it was wildly faulty, it would be hard for any item like a monitor to produce field strengths of any significance, in my view. All modern units comply with the necessary regulations. The PC even less so, since it will be effectively shielded.
Andy.
Posted on: 09 February 2004 by Rockingdoc
Exposure to this site for six hours at a time could certainly be harmful to your health, and a numb face the least of your problems.
Seriously though, how about the hypothesis of flickering light causing a migrainous reaction? You wouldn't need to have headache, but it would be likely.
Good point - what is the PC screen refresh rate set to?
In XP, right click the desktop, click properties, the settings tab, then the advanced button.
Click the monitor tab and make sure the Screen refresh rate is set to either 72, 75 or 85Hz, if supported.
DON'T set it higher, there's evidence that a higher refresh rate than this can make things worse.
Andy.
Posted on: 09 February 2004 by Derek Wright
Also get your eyesight checked - if your glasses are not correct it could cause you to look at the screen with the head tilted badly - if you use varifocal lenses you probably do not have a adequate view area for the screen viewing distance which is different from normal reading distance.
Derek
Posted on: 09 February 2004 by Chris Brandon
From experience gained from many years working in I.T. I would suggest....
1. (If not already running at) Increase the screen refresh rate to 85.
2. Decrease the brightness and contrast....do you really need screen images to be "burned" into your eyes and brain ?
3. Relax your face,eyes and body whilst using your pc.
This may sound daft,but out of the amount of time you spend on your pc,how much time do you spend with an intense frown of concentration ? ( I can virtually guarentee that this will amount to FAR more time than you expect).
-People also have a bad habit of tensing up whilst using a pc .....part of bad posture
4. Try and get the environment & ergonomics both comfortable and correct. Besides temperature,lighting and humidity etc,also do what you can to attain correct posture.
I am sure that there are many other variables,but you need to make a start somewhere.
Chris
Posted on: 09 February 2004 by max in hampshire
Thanks for the ideas so far.
I thought playing with the refresh rate seemed pretty straightforward nice easy to follow instructions so Ihave had a look at that. But having changed the refresh rate (it was set at 60) all the icons at the bottom of the screen have all but disappeared. So, how do I get my icons back?
Also, whilst I am happy to explore all of my personal bad habits, frowning, posture and the like I can't see that these will have changed with the arrival of a new computer.
Max
Eh! Wierd Wink
I suspect the new refresh rate has messed up the screen sizing - use the monitor's on-screen display to re-size the picture to fit.
If not, I haven't a clue, maybe the faster refresh is too quick for the eye Smile
It's frustrating how the simple things with PC's become so hard sometimes!
Andy.
Posted on: 10 February 2004 by domfjbrown
60 Hz!?!?! No blooming wander you're not feeling well... I can see flicker up to 85 Hz on a good day, but 60 is EVIL!
As said, your monitor's probably now overscaning due to the difference in refresh rate; use the centring/size options on the monitor's menu to fix.
My ancient Athlon 750 has sounded like a badly maintained tractor since day 1, so noisy computers are not alien to me. Very annoying though - how much noise does a fan need to make for crying out loud?
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
