Toslink to AES/EUB XLR?
Posted by: MontyW on 13 May 2009
Hi,
Does anyone know if there is a 'box of tricks' that I can use to convert a Toslink to AES/EUB XLR?
Thanks.
Posted on: 14 May 2009 by james n
Weiss does one.
James
Posted on: 14 May 2009 by goldfinch
There are a few more, haven't tested any of them though.
Hosa ODL datalink
Digimatch
M-audio Midiman
Posted on: 14 May 2009 by fixedwheel
Behringer SRC2496 - list is £209 inc VAT
Will also do A to D, D to A etc.
John
Posted on: 14 May 2009 by MontyW
Thanks for the replies.
Posted on: 15 May 2009 by MontyW
Hi,
After doing a little bit more looking around I have found a converter from a company called Lake People:
http://www.lake-people.de/inde...ng=eng&typ=2&nr=c430
This looks ideal for my purposes, but can I ask does anyone know if this converter would introduce jitter into the chain and have a detrimental effect when using optical Toslink to AES/EUB - XLR?
Posted on: 16 May 2009 by james n
Just out of interest why do you want to convert from toslink to AES ?
James
Posted on: 16 May 2009 by MontyW
I want to set up a second system that uses a pair of Genelec monitors that accept AES/EUB via XLR.
