Any one remember?
Posted by: garyi on 22 August 2001
They were about 20 quid, and in my opinion made no difference whatsoever infact they smaked of a con.
anyone still using the magic bit of plastic?
For someone with a cheap CD player, who likes to store their CDs in binders with plastic sheets, I think it's a useful tool. It cleans up the sound noticeably.
-=> Mike Hanson <=-
Is this really necessary? If so - what do I need to buy. I've only just entered into the world of CD and I never bother cleaning records so I may be missing a trick here.
Nigel
Other than that, I usually don't clean CDs (unless someone gets their sticky fingerprints on them).
BTW, when you are sitting an unprotected CD on a table, don't set it label side down! This is where the information is encoded. Instead, set it shiny side down (i.e. label side away from the nasty surface). Even if you get a minor scratch, the laser will be able to focus past the scratch (just like you do when looking through a window screen). Even if it misreads due to a scratch, you can probably buf it a bit to cure the problem. However, if you scratch the label side, you've permanently damaged the data.
-=> Mike Hanson <=-
Thanks for the info on the data incoding, I didn't know it was on the label side. So saying though in another thread I was refering to a Pink Floyd disk I have which has been trashed on the label side, however its one of those printed numbers like the zappa CDs the coating is different, anyhow that plays fine.
Since the label side will be coated differently form CD to CD, you'll find that some are quite fairly robust. However, some are exceedingly fragile.
Even more of a problem are CD-Rs, which are very easy to scratch on the label side.
-=> Mike Hanson <=-
I'm using similar plastic disc as per your description.
There are no markings on it al all - got it as a free gift from a former NAIM dealer.
I store it rapped with a rubber string in a slightly bent position to keep the elasticity.
I use it, if the magnetic puck doesn't fix the CD properly on my NAIM CD 2 (and I'm to slack to prepare the little rubber rings)
Sonic improvements? Well, there may be, if one believes so....
Urs ![]()
However, scratches to the clear side are easily washed and/or buffed away. That's why, when I set unprotected CDs on a shelf, I always set them label-side-up.
-=> Mike Hanson <=-
