Coating the Karik with lead
Posted by: quincy on 12 October 2001
He was on-the-button ... day versus night.
Any of you cats tried something similar ?
Craig
no holes in our arse
I do remember that my Naim CD3 did not like having much weight placed on top.
- GregB
Insert Witty Signature Line Here
Basically the player sat on one or more layers of glass which were separated/supported on ball bearings that rested within fastener nuts. The glass sheet on top was 'stuck' on with three or four large blobs of Blu-Tac. It came to be known as the 'Vukwich' in honour of its creator who was aptly named after a wild dog. (Vuk, n., p. Vook; a wild dog that roams in packs (Websters)) ![]()
I believe that some forum members may be still be using this method of isolation in leiu of investing more heavily in dedicated supports.
You friend Dave's lead idea sounds like an easily reversable tweak worth trying.
Craig
The lead is permanently held in place by Walmart's finest cyanoacrylic acid.
another dave
dave
MVP/AES andfullofshite
[This message was edited by dave simpson on SATURDAY 13 October 2001 at 05:09.]
yea boy!
dave
He deserves extra flies tonite!
dave
Do you have any pictures? Was the lead plced just on the base plate or the outer case also?
Would strips of lead tape do the same job? Easily reversible, self adhesive. You can even make patterns!
Milan
Easier to conform to contours by applying heat, melting lead, and pouring into the Karik. Allow to cool sufficiently before attempting use, though! ; )
disclaimer : if you're dumbass enough to actually do this, don't come crying. Oh, and make sure you tie your shoelaces before walking down stairs.
I was serious about the lead dangers, though.
Rico - SM/Mullet Audio
Originally posted by Rico:
Easier to conform to contours by applying heat, melting lead, and pouring into the Karik...._disclaimer : if you're dumbass enough to actually do this, don't come crying.
Rico,
I suspect the fumes from melting the lead might be worse than environmental contamination from lead sheeting.
cheers, Martin
Originally posted by Sproggle:
He began to talk about the Hamiltonian of psycho-magnetic interaction, which is (as far as I can remember):H = -Rzh_a.H_/2pi
where R is the psychomagnetic ratio, z is the psychic state, h is Planck's constant, _a_ is a psychic polarisation vector [at least I think he said that] and _H_, of course, is the magnetic field.
Hm.....
it must be devided by 4pi.
Reason here is that he neglected the third and forth dimension.
OK, maybe in a "flat earth" calculation he could skip
the third dimension, but at least we all know how important TIMING is ;-)
So, he missed the time in his calculation....
If you now integrate over your hamiltonian it gives the corect answer. (42)
Enjoy live!
-mb
...which I, as a mere human...
I've seen the pic of you. Go on...post it again for the uninitiated ![]()
- GregB
- GregB
