Audio Nirvana
Posted by: Nic Peeling on 26 September 2002
Since I obtained some great small loudspeakers for my kitchen system (Dali Royal Meneut) I have been totally happy with it. It is ridiculously overspecified (CDS1 and 72/140), but I got the kit at great second hand prices. I am totally happy with it - audio nirvana. I never think about the system I just listen to the music and am constantly thinking "this is great".
The main lounge system is what used (pre the arrival of the 552 and NAP 500 era) to be considered high-end. A good US CD transport and DAC, 52 and 250 playing into a whole sequence of speakers. I have been permanently irritated with the system - I kept listening to it as Hi-Fi instead of enjoying the music. I felt that there were a number of reasons for this. Firstly, that I listen in a more concentrated way in the lounge than in the kitchen. Secondly, that expensive systems tend to have very good speakers that reveal flaws ruthlessly. Lastly, that having spent serious money on the system I had very high expectations.
I embarked on another attempt to find audio nirvana by trying to find some loudspeakers Sue and I really liked. We heard the Wilson Benesch Arcs at the Bristol Hi-Fi show and really liked them. Maurice and Norman at Audio Excellence in Worcester offered us a weeks loan of a fully run in pair, which we gratefully accepted (great service in my opinion). We were very pleased and exchanged our speakers for the Arcs. 100 hours of running in later we were happy bunnies. It was not audio nirvana - there were too many obvious faults (such as ploddy bass) - but we found the Arcs very enjoyable. Then Norman suggested we try bi-amping the Arcs with another 250. I knew Naim did not really recommend bi-amping, and a colleague at work who used to design amps explained how bi-amping bought you very little compared to a proper active system (mainly a reduction in current intermodulation between bass and tweeter). The result though was audio nirvana. I cannot really describe the improvements because I now listen to the music not the system, but for me this was the upgrade that finished the upgrade cycle. Maybe its time think about an AV system.
Nic P
Posted on: 26 September 2002 by David Antonelli
Nic,
Congrats on your audio nirvana. I was using a 250 with my WB ACT 2s and it wasn't quite enough to drive the lower registers to the highest level of satisfaction - although it was still marvelous. They are a little more demanding or power than the specs would make you believe, or rather they really blossom into something special when driven by the best amps possible.
dave
Posted on: 26 September 2002 by Paul Davies
Nic, have you ever considered using your CDS1 in your main system?
Posted on: 27 September 2002 by Nic Peeling
Paul
Yes I have tried the CDS 1 in the main system. I have a Theta Data Basic, connected by two timebase Link Conditioners to their top-end DSP Pro Basic DAC. I did an A/B comparison and to my surprise they sounded almost identical. Same level of detail, same PRAT, similar tonal balance. The only real difference was that the Theta had much better imaging. Being a round earther who greatly likes Naim's PRAT this made the Theta the better choice for the lounge - obviously the lack of great imaging is not a problem in the kitchen. In addition the Theta allows me to connect to a Pioneer 609 CD recorder which I have in the lounge.
Nic P
Posted on: 27 September 2002 by Justin
I don't mean to bring you down, but after changes that I thought really "did it" for me, I would find myself irritated again a month or so later. I have found through mutiple upgrades that I am very much more happy with mid-spec naim gear than the more expensive stuff.
Permit me to make the following suggestion:
Pack up your lounge system and put it in the closet for a month. Cart out your Kitchen system (including the speakers, which I realize may be too small to fill your lounge) into the lounge. Spend some time setting it up correctly on good supports (nothing fancy is required--just something light and rigid like SO or Target will bring the goods (if they are there)).
Listen for a few weeks and see how you feel. You might find that on balance you are happier with this system. I know it sounds crazy--but I have aften found it to be true.
Then, if you like what you hear-------gradually------introduce your more expensive gear into your lesser system and see where that takes you. Try cd player, then amp, then pre-amp, etc. I don't think the sequence is essential.
judd
David,
I know what you are talking about smile ... but it may well not happen. A while ago a contributor (who regrettably was banned by Paul S) who wrote under the name of Tanais Fox actually downgraded from top end (mainly Naim) equipment. As an aside, it was linked to his delight in the improvement that extra Mana stands gave him - but the threads that followed had a very interesting discussion on whether very expensive Hi-Fi gear is really worth it. This struck a chord with me because I kept being so unsatisfied with my lounge system. Given I had bought a lot of it new I could not bear to lose so much money selling it and then buying a cheaper system, so I struggled on putting good money after bad. I had virtually given up hope of being happy and was genuinely surprised to end up happy. I have spent way over 10K GBP getting there. Was it worth it? All I can say is that with the benefit of hindsight I think I would not go anywhere near so far up the upgrade path again, and I would buy more kit second hand. I am shocked at what I have spent ... and I now see a pre-amp (the 552) that costs about the same as my entire system!!
Nic P
Posted on: 27 September 2002 by Rockingdoc
A CDS in the Kitchen!!!!!
I suppose the cooker point gives you good mains, but what do you clean it with, oven cleaner?
Rockingdoc,
I use brillo pads smile . As you probably suspected only the speakers are in the kitchen and the rest of the kit is in the next door room. Unfortunately the speakers do get greasy which I suspect will not do them a lot of good over the years - I leave the grills on to try and protect the drive units.
Yes, I know the CDS is over the top, but I will not tell you how little I paid for it ... I hate to see a grown man cry!
Nic P
I wonder if Naim still do the upgrade to CDS2 for 1500GBP? I thought it money very well spent.
Posted on: 27 September 2002 by Markus
Why? Because now that cat is out of the bag!!
Which cat? The cat that helps us understand that there is not, in an absolute sense, a direct correspondence between how much one enjoys their system and how much one has spent on it. I would go so far to say that there is a real risk that the more one spends on it, after some point, the LESS one is likely to enjoy it.
Why do I think this is so? Because the part of the brain that enjoys the music in a free, spontaneous and carefree way gets all messed up when the part of the brain that *analyzes stuff* comes over and starts asking questions. Questions like
"is this right?"
"does it sound better now? (after spending X dollars on an upgrade)"
"was this expenditure worth it?"
"how does component compare with that component?"
"how could I make this sound better?"
Not to say that the process of comparing pieces of equipment can't be enjoyable, in and of itself, but that such enjoyment isn't the same as that generated spontaneously by the brain when we listen to music without caring about whether or not we are squeezing every last ounce out of the system. My experience is that when I listen to a system, knowing full well that it could be better or that I am not "getting every last ounce out of it" and then putting that knowledge behind me and forgetting it, I am much more likely to really relax, kick back and enjoy the damn music.
A study of the "hi-fi hobby" as reflected by the audio press, letters to the editor in hi-fi magazines and this forum has told me that a lot of people create lovable, livable systems and then "mess them up" by upgrades that don't add to the enjoyment, changes that aren't improvements and buying equipment beyond the point of diminishing returns which ultimately create disatisfaction and the need to upgrade something else in order to extract that "little bit more" that should be there. Witness the endless parade of cables, digital to analog converters, tweaks, mods, etc that flow through the audio industry.
Going back to the first post in this thread, I think Nic hits the nail on the head in his description of his listening experience(s) in the kitchen and in the lounge. And Judd/Justin (your cd 3.5 continues to provide satisfaction in St. Louis!) is right on target too.
While the musical value of the new line is yet unproven to me personally, the great genius of Naim has been their creation of classic components of lasting value that have helped us all achieve this listening nirvana, especially those which, through history are now priced down in the "everyman" range, like 32.5's, naits, 72's and 140's.
Let's hope the new range pushes our enjoyment even closer to the horizon!!
Have a great weekend!!! And enjoy the sounds,
Markus
Posted on: 27 September 2002 by jpk73
"is this right?"
If anybody still asks these kind of questions -like me: what to do...?
My system (see profile) is quite OK, but music doesn't really release from the speakers. Does ist depend on the speakers, if yes: what are the speakers I should try? Or am I crazy: should I be satisfied with what my system does...?
- Jun
Posted on: 03 October 2002 by Markus
Tinitis! F**k! is right!!
I'm assuming you've seen a doctor about this? And not just any doctor, but the BEST that can be found for this problem?
What are the symptoms? How did it happen? How did it come on? Was it triggered by listening to loud music?
Wishing for your speedy recovery,
Markus
Posted on: 03 October 2002 by Thomas K
David,
Sorry to hear that. But don't despair, tinnitus is often a temporary thing.
A friend of mine was afflicted last summer, and by not listening too loud, and taking a relaxed attitute towards work and life in general he managed to get rid of it (perhaps it would have gone anyway, but that's what he was told to do).
Obviously you'll have to get an expert's opinion. So, sorry if your physician has already told you all of this.
All the best,
Thomas
Posted on: 04 October 2002 by David Stewart
David,
I had a quite bad problem with this a few years ago. A book I read at the time, suggested that dietary factors could have a major influence. Dairy products, particularly cheese and also chocolate were thought to exacerbate tinnitus by creating catarrhal congestion in the ear. I found that by drastically reducing my cheddar intake the problem largely disappeared and hopefully won't recur. It might not work for you but could be worth doing your own research along the same lines. There are lots of resources on the web which might help. Good luck anyway.
