SL2 Advice requested
Posted by: Goldstar on 03 March 2004
I am about to order SL2's, has anyone experience of these and any advice?
They will be driven with a 52/250 combination.
Cheers Robert
Cheers Robert
Posted on: 03 March 2004 by NB
Robert,
Excellent choice, the SL2 is one of the finest speakers around.
Your 52/250 combo will be able to drive it quite nicely and the SL2's will reward you if you up-grade the amp in the future.
Enjoy your new speakers
NB
NB
Posted on: 03 March 2004 by blythe
Cheers Robert
Great speaker but do expect to have to run them in for a number of weeks - seems like 8 weeks will have them singing!
Also, if you're planning to set them up yourself, make sure the PIPS are the right way up - I think that's with the little "bumps" upwards - someone else may be able to confirm this.
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
Posted on: 13 March 2004 by garyi
If you havn't heard them don't buy them.
Posted on: 14 March 2004 by audiogoose
I agree about the long burn in time. Mine still seem to be improving ever so slightly after 10 mos., or so. This is mostly in the bass, but the highs seem a little smoother, too.
I drive mine passively with a pair of 135's which seem to be a good match. I have mine sitting on concrete patio slabs.
It is a must to follow the assembly instructions carefully, and to make sure there is no rocking motion in the plinth. Also, be sure they are level and that the "tits" of the spacers are pointed upwards. Otherwise, sound quality will be compromised.
I am at present in the process of getting ready for a move to a new house and am trying my best not to have to sell my pair out of necessity to raise some need cash. So far, I haven't been able to bring myself to put them on the market.
Again, if you buy SL 2's, be very patient and allow adequate break-in time. You will be rewarded with a very musical experience.
Posted on: 29 March 2004 by Goldstar
Hello Audiogoose,
I see that you have equipment racks between the speakers, I thought that was a no -no?
I plan to have a Sony T.V. in the middle of the back wall on a low table. The speakers will be far enough apart so as not to effect each other.
I hope!
Do you think this will work?
Cheers Robert
I hope!
Cheers Robert
Posted on: 29 March 2004 by NB
Robert
____________________________________________________________
Its a big no-no!
The equipment will interfere with the soundwaves and muddle the sound. If you have to have equipment between the speakers make sure the drive units are in front of the equipment.
NB
Its a big no-no!
NB
Posted on: 29 March 2004 by audiogoose
Yes, I would like to arrange things differently. We will be moving soon into a new house and I will have more room for my system. I am already planning to have the electronics on a different wall from my speakers.
I just hope I don't have to sell the SL2's to finance the move.
Jerry
Jerry
Posted on: 29 March 2004 by Dev B
Originally posted by NB:
Robert
Its a big no-no!
NB
Equipment behind the plane of the speakers front baffle will not have a bad effect, it's a problem if you put sharp edges in front of the speakers you get sound reflections arriving at you at different times which is bad.
What to do with the damn T.V. ?
The obvious solution would be to install one of those flat screen jobbies on the wall, but after paying for the SL2's I'm skint!
Ain't life wonderful.
Robert on the road to Nirvana (or divorce)
Hi Ken,
Posted on: 29 March 2004 by Rockingdoc
Audiogoose, were you aware that using valve amplifiers in a Naim system is an imprisonable offence here?
I just mentioned using Sugden solid states in mine and had the post deleted!
Mea culpa. Actually, the valve amps are not connected to the system.
The 135's pictured on the rack below the turntable are driving the SL2's.
I must confess that I did try the little 8 wpc SET brutes on the SL2's with good results, so they must be relatively easy loads.
I will, however, practice self-flagellation for a week to punish myself for such an egregious offence.
Jerry
Jerry
Posted on: 29 March 2004 by ken c
goldstar, i just wanted to find out whether you now have your SL2's and how you are getting on with them -- but at the point of posting, my pc just froze.
enjoy
ken
enjoy
ken
Hi Ken,
My dealer is on holiday until 14th April and will deliver the SL2's then.
He kindly loaned me a pair of SBL's which are doing stirling service. After my Audio Physic steps they are quite a revelation!
Cheers Robert
p.s. can't wait for the big day! do let me know how your SL2's are sounding.
Cheers Robert
