Phono Boards
Posted by: plynnplynn on 31 March 2002
Naim cartridge boards are available in the following configurations:-
Cartridge and high level options
Moving Magnet type "N" 2mV, 47 KOhms
Moving Coil type "S" 100µV, 470 Ohms
Moving Coil type "K" 100µV, 560 Ohms
Moving Coil type "E" 400µV, 560 Ohms
(from the Naim site).
Unfortunately I cannot find the pages. Can anyone help?
Also does this mean that boards are interchangeable across the full range of pre-amps? ie will a phono board from a Nait fit a 32.5, or an 82 etc?
Terry
Try :-
Main website; components; amplifiers; preamps; 52; specification.
You should find the list of optional phono boards that can be specified for your brand new 52!!!
Same boards can be ordered up separately.
Have a look at 82/112/102 also.
Don
Terry
Originally posted by plynnplynn:
Thanks for help. I downloaded pre-amps manual and got the info there for current amps but not older equipment. Does anyone know of a site which has that information?
Terry
Managed to find something myself at http://www.pfmedia.demon.co.uk/. Extract below:
NA323 K/S Phono MC
NA322 MM Phono
NA326 Fixed Line Input (link board)
NA328 Variable Level Line input with some HF filtering
NA324 Tape Output Buffer
NA321 Main Gain, Output Drive
NA325 Switch on relay
NA729 Time-Aligned input buffer boards - AKA 72 Filter Boards
Terry
Terry
Does anyone know of any dealer who specialises in selling boards second-hand eg phono boards, 72 boards etc ?
Terry
...but 72 boards ie time alignment are rare... I bought mine new.. and haven't seen any secondhand in 2 years as a loot watcher.
John
Shore
I agree with John - I've not seen any on Ebay or Audiogon either. However, you can find 32-5s with the 72 boards if you are patient. The price differential between selling a decent 32-5 and buying one with the 72 boards is almost always less than the $325 dealers will charge. I did this myself.
Erik
Erik
one just went on ebay all in for £212... have to wait again now.. was a late one also with the selector at the rear.. (I e-mailed him for interest).
John
Shore
[This message was edited by johno on WEDNESDAY 03 April 2002 at 10:38.]
Phono boards for the old style are very common on ebay, running $20-$50 depending on revision number (most recent being -4 for mm and -5 for mc).
For the new style boards, prices get closer to $80, as these are much less common.
--Eric
Terry
I have two clean virgin ones sitting on my desk in front of me, model 322/4 and I'm unsure of vintage.
They've been totally un-fiddled with since I don't use MM, they came from a 42.5 that now has the phono inouts as line level.
I have no idea what you think they are worth, but I don't want any cash for them, a CD in exchange would get them winging their way towards you. I have a list of 'wanted' discs ![]()
Drop me an email via the link in the profile - don't forget to remove the NOFINSPAM bit!
Andy.
