That warped disc mystery ....
Posted by: Haroon on 26 November 2003
Got out a 12" double white label pack the other day (first record I choose for listening) and both discs were warped the same way and I cant figure out how it happened? When I bought them they played fine and were not warped. The are stored uprightish (slight slant) on the floor, near to the front - but about 7/8 records infront of it. the records either side are fine, and they are not near any heat source.
So why do discs warp? and what can I do about it? did a search for other posts about warped discs, which turned up unscuccesful experiences of putting it in the oven
- dont wanna go there. Also something about leaving it pressed for theee months - any luck with that peeps?
At the moment I have them wedged in my records.
[This message was edited by Haroon on THURSDAY 27 November 2003 at 02:49.]
Posted on: 28 November 2003 by Haroon
114 people viewed this topic and not yet one person who's managed to flatten a warped record
There must be a way ...
Posted on: 28 November 2003 by J.N.
The old advice used to be to put the disc (in its inner sleeve) between two sheets of glass and put some heavy weights on top for a week.
Hefty books are ideal.
Do it in a warm room if possible.
Good luck.
Good luck.
Posted on: 29 November 2003 by blythe
Could it be that your hot water heating pipes run under the part of the floor where you had the records stacked?
That would cause localised heating which may be the cause......
Large weights on top a warped records for a period of time can make a difference, but will not flatten a warp 100%
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
Posted on: 29 November 2003 by minime
2x 10 mm glass weighted on a nice sunny day does it 99% for me
Posted on: 29 November 2003 by Manu
Sure, but does it sounds as good as before?
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 30 November 2003 by prowla
Well, you have to take the glass off before you try and play it!
Paul Rowlands
Posted on: 30 November 2003 by Haroon
Well give it a go - have to be in about 7 months now ... with this freekin' weather
There are no pipes under that floor ... mystery continues ....
Posted on: 01 December 2003 by ThomasT
Hi Haroon,
I managed to flatten a badly warped record between to glass plates in an oven, not an usual one but the incubator for our cells in the lab ;-). The advantage is that you can adjust the temperature very acccurately. I finally succeeded with 60 °C for one hour (50 °C and 55 °C didn't work). It still does not sound excellent but before the record was not playable at all.
Good luck,
Thomas
Good luck,
Thomas
Posted on: 01 December 2003 by domfjbrown
I've had a couple of LPs do a spontaneous warp as well - for no reason...
I have one LP that was really badly warped (didn't notice it when I bought it!); it's wedged in between about 300 others and stays flat for about 1 side's worth of playing. You then turn it over and... D'oh!
The odd thing is that my copy of Hole's "Pretty on the inside" is really badly warped as well, but sounds fine! Mind you, that might be due to the grunge factor...
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
Posted on: 01 December 2003 by minime
could never play them before too warped.
why else would i sit in the sun watching them level out when i could be inside playing them on my t/table
Posted on: 01 December 2003 by Haroon
might give this oven thing a go - just need to get some glass.
I ve just remembered some other weird things going on in the house - the clock in my room had stopped twice in same week I found the warped record, clock is working fine now, battery just popped out of place a little strange as its about 8ft high on the wall
Also in another room is a very thick glass dish - this split in half whilst my folks were watching TV
this happened a few days before the clock.
Maybe its just the climate ... the mystery continues ...
Posted on: 02 December 2003 by prowla
Don't suppose you live on a ley line do you?
Paul Rowlands
Paul Rowlands
Posted on: 02 December 2003 by domfjbrown
Oh no, now you've done it... That's brought on a Neil-ism...
"OH NO!!! We've got a Polterghoost!"
What IS a ley line anyway??
Posted on: 03 December 2003 by minime
joking aside i have visited a well documented house and the glass splitting was one of the signs of poltergiest activity.
Posted on: 03 December 2003 by Haroon
my mum and dad think its supernatural ... but take it as a sign that somethings left the house or entered hmmm.
yeh so what is a ley line??
Posted on: 04 December 2003 by domfjbrown
So, if you have a TV, you know what to do with it - lug it outside and leave it there...
Being serious again now, I'd be totally freaked by that glass splitting thing. In my old house share in Reading, the house cat used to miaow at the walls for no reason, and lights would turn on by themselves (at the switch!). There was an old weathered stone in the wall at the end of the garden and we did wander if it was a headstone or something; once, my housemate nearly fell down the stairs in shock; she'd seen a reflection in the mirror (someone behind her) and when she turned round there was nothing there...
Posted on: 04 December 2003 by Haroon
I think there is a perfectly natural explanation .. my bets on the climate or something like that affecting the light switch and glass and maybe a subconcious trick on the eye a shadow appearing as something else. Well thats the way I explain it away at least - makes it easier to sleep at night
Posted on: 08 December 2003 by steveb
Warped LP's
Simple- steam iron, low setting, damp tablecloth, but don't press too hard, don't want to damage those precious grooves do we!!!
Steve
Steve
Posted on: 11 December 2003 by minime
it could be a ghost with a "warped" sense of humour
Posted on: 12 December 2003 by ys
I saw a product from Clearaudio which is in fact a metal ring, it seems to be a good tool to deal with warp records but I was told this thing is expensive.....
Posted on: 12 December 2003 by Nigel Cavendish
steveb
I thought you were taking the mickey... but it works a treat!
cheers
Nigel
cheers
Nigel
Posted on: 14 December 2003 by Haroon
Originally posted by steveb:
Warped LP's
Steve
Im still thinking this one through in my head - it just seems a non no to me. I might get the courage for it one of these days though
