NACA5: minor upgrade, major questions
Posted by: rocketeer on 27 November 2002
Dear Members
My dynaudio contour speakers are connected to my all naim system via OCOS speaker cables (dynaudio recommendation). Recently, i purchased s/h NACA5. Here's what i experienced:
The OCOS produces a tight and thin bass, but also a little less controlled. With the NACA5, bass is more tuneful and also more controlled. The midrange is fantastic and wide open with the NACA5! A clear winner over the OCOS. The NACA5 in fact seems to be more natural and musical.
But what happens to the heights!? Were they so colorful and silky with the OCOS, they become quite pale and harsh with the NACA5. This becomes very evident with voices in the pronunciation of "s". It is quite an "sh" or an "z" through the NACA5. What could be the reason for this (Although not a expert, i think i did a good job on the soldering of the naim plugs at the poweramp ends. At the speaker ends, i striped the insulation and fixed the blank cable with the speaker's plug screw)?
When experimenting with the speaker cables, i noticed something else that pretty much amazed me (with both cables): The contours are known as power hungry. With my 140, at "9 o'clock" position on the preamps volume knob, things are already quite loud. At "10 o'clock" there's already too much compression to retain musical harmony. But my normal "10pm-2am" listening level anyway corresponds to position "8 o'clock". I always had the impression that the 140 could do well at this level. But i noticed quite a substantial sound improvement when listening even below that level: the separation was much clearer, more details, the depth much increased! I was quite puzzled about this effect. I know that bolides other than my cute little 140 could drive my contours much more accurately. But is this already relevant at such low listening levels? (Do i need another poweramp?)
thanks for any feedback.
rocketeer
[This message was edited by rocketeer on WEDNESDAY 27 November 2002 at 15:56.]
Posted on: 27 November 2002 by skraft
Dyns tend to be power hungry. The 1.1s should be fine with the 140 - I have run them from a Nait5 beautifully. Anything from the 1.8 up, needs more. I run 1.8s on a 180 and it's fine. But a 250 is definitely a better driver.
Posted on: 27 November 2002 by rocketeer
1.3 MkII
Posted on: 28 November 2002 by Philip Pang
Rocketeer, in my experience, they take 6 long months to run in properly, average play a day, all volumes. But when not run-in properly, the treble's thin, peaky, bright, with undeveloped bass. If after 6 months of constant play they still sound bright, look further up the chain, at your set-up/ room acoustics. Bright the naca5s are not (oh no! yoda)
If you head-bang, maybe half the time, at the end of which you could end up a little deaf.
Once you look carefully into your set-up, the highs on the naca 5s are anything but harsh... clean without being recessed, clear, detailed, yet full.
In a full Naim system of course.
Don't coil them, and if you can lift them off the floor with some small rubber blocks or perhaps styrofoam cups. I would keep them well away from the power cord cables...
My Naca5s have never sounded thin or bright.
Good listening; the music's groovin' frightfully more.
Philip
naimniac for life
Posted on: 28 November 2002 by Linds
I'll second that.
I've used NACA5 in a thin and bright system and it totally unthinned and unbrightened the sound.
Sound was solid and deep. However, within my system I felt the vocals were a bit "masked", but let's not get into symptoms and causes!!!
!!! There's always money somewhere for the next upgrade... !!!
Posted on: 28 November 2002 by rocketeer
hi folks
thanks for your feedback. "thin or bright" was never the issue with the naca5, though. it was some harshness in the treble which pretty much reduced when i bananaed the speaker ends. and things are even getting better over time. the naca5 really seems to be the "long arms" of any naim amp.
rocketeer
[This message was edited by rocketeer on THURSDAY 28 November 2002 at 22:05.]
[This message was edited by rocketeer on FRIDAY 29 November 2002 at 10:09.]
Posted on: 28 November 2002 by hi fi fo fum
If your speakers are by-wire plug Nac A5 into top terminals ( using Only Nickel plated deltrons) not gold take Nac A5 a short piece and jump down to lower terminal....and report back
Posted on: 28 November 2002 by Lightkeeper
Hi Rocketeer !
I feel that I must answer to this because I was told you to buy Naca 5. After changing Straight Wire Maestro (560$) to Naca 5 I have realised same thing (not problem). There is no problem in Naca 5. Even you have an awesome Naim system which is acually missing a speakers, I believe that you have just a fragments of Naim sound.
After one month of initiation with my Naca 5 I was realised that this cable is not bad or good, it is a perfect match for my amp and speakers.
It is also good to know that how many more Naim components you have in a system, every next nonnaim component which you will maybe add is less welcome. Now you have a GIGO (garbage in garbage out) cable and that treble "anomalies" which you hear is not made by Naca 5, believe me, they are on your recordings, but the Ocos (like my ex Straight Wire) didn't let them go out like all the positive things you can hear now.
For me, Naim is not hi-fi, there is no silky heights or such a pleasures for Corega tabs users.
How much meters of Naca do you use?
Did you plan to go for a Naim speakers?
Just listen, let your cables to meet well your speakers, room and electronics, relax and you will soon understand what you've been missing.
Ozren
Posted on: 29 November 2002 by rocketeer
Hello Ozren
thanks for the shout out. i agree with you on naca5. after a few days i don't get distracted much by "effects"! music repro has become much more natural, real and relaxing with the naca5. no doubt that it is a perfect match with naim electronics (length of my naca5 is 7 meters).
i also agree with you, that naim components come to their best in a full naim system. To this, IMHO, speakers are not necessarily incorporated. This is shown by the fact, that many people have a full naim electronics system with non-naim speakers, which works perfect. I have sticked with my dynaudio speakers for more than a decade now. i always had the impression that the electronics could not do the work properly, until i got into naim (three years ago). i gave naim speakers twice a try (credos, sbls), but they did not convince me, in terms of overall balance. And i don't think it was due the short listening session of only a few hours. So, my conclusion is that "naim sound" is made by their electronics, not necessarily by their speakers (ok guys, i ducked down, you can shoot!)
cheers
rocketeer
Posted on: 29 November 2002 by Lightkeeper
Rocketeer !
Glad to hear your reply.
About Naim electronics and nonnaim speakers I know that there is very much happy combination...Royd, Neat, Epos, Linn, Quad etc, but that's just accidental match which is SURE electricaly and sonicaly a little bit far away from all Naim system synergy. Even some other speakers work well with Naim, that doesn't mean that there is many speaker compnaies around which Naim amplifier can made very welcome.
My believing is that (example) Linn speakers and amps are more far away from Naim philosophy than people think. In your case, Dynaudio is very interesting speakers, but I think that force Dynaudio to play with Naim is like force Paul Mcartney to sing like Ian Gillan.
I believe that most important factor to get musical enjoyment is synergy. I can more enjoy in all Rega system than combined with Naim, but also can more enjoy with all Naim than all Rega system, ofcourse. Let's just say one more, you know Citroen AX, will be that car better if you put on it a 225cm wide tyre, certainly not, but it would be more atractive for much people, people who don't know and don't understand that this was stupid.
I really don't understand that you like more Dynaudio with Naim than SBL's. Maybe you are auditioned them with Ocos?!
I should tell you this - I have had Epos12 speakers before Intros. Epos are (some says) designed on the idea to work best with Naim. That was not true. Yes, that speaker have some sound characteristics which are well known for Naim gear, but simply don't work good with Naim.
When I was add CD5 to Epos the sound was blured, extremly dry and every guitar sounds the same.
I do not equalize that teory with Dynaudio, but this is just example. The speaker is not a speaker.
Nothing personal
Ozren
Hi Ozren
This makes me laugh for two reasons: first, the comparison is funny, second, probably you never had the occasion to listen to a dynaudio speaker of the sophisticated range, such as the contours.
This one is even funnier! Hey Ozren, my abdomen aches because of laughing, just imagining a car with 225cm wide tyres mounted. Ok, i stop now, i understand what you meant (225mm). Although i find naim's black boxes very attractive, i do certainly not care about cable attractiveness, especially when it comes to the NACA5! Sorry, but your comparison of mounting wide tyres to a car with installing a sort of speaker cable to an audio system is not much insightful...
No, in fact it was the NACA5 with the sbls and some other white cable (NACA4?) with the credos. Can't remember the credo system, but the sbls where with a cdsI/82/hi/250. It was at a guys place next to mine, who advertised them for selling. He even got somehow embarassed, when i asked him for what reason he was selling the sbls. The reason why I did not go for them: the midrange sounded very dark, the heights were very reserved and somehow dusty.
Ozren, hopefully from your view, i kept this constructive. At least, it was meant so, because i appreciate your opinions. Speakers are a matter of taste, whereas electronics (including cables here!) are a matter of naim!
regards
rocketeer
Yes, I was heard many of Dynaudio. My good firend like them much, he have all Accuphase system with C2 Confidence series.
You know what is good for you.
I will be most happy when you will be happy, trust your ears and heartm cos' we are all different.
For now...
Ozren
