Software Wishes for the HDX
Posted by: Hans Vereecken on 11 January 2009
* Enhanced possibilities to check if the ripping process was accurate.
I've already experienced that EAC easily outperformes the ripping engine from the HDX.
Suggestions : connection to accurate rip
% corrected bits per number (like EAC)
* possibility to delete individial numbers (via the PC)
* disable scanning of a NAS
It happend to me many times that I start playing from a NAS, suddenly the music is interupted while the NAS goes into
scanning mode. So I have to wait 5 minutes to resume playing.
When playing from a NAS is ongoing, re-scan should be put on hold.
* Possibility to add covers to the database
Sometimes the HDX can't find a cover. There should be a possibility to add them via the PC.
* Connection to last-fm
Posted on: 11 January 2009 by Paul Stephenson
sorry hans your dreaming, not in any of the tests we have done and we have done lots and lots and lots
Posted on: 11 January 2009 by Dev B
Is there any chance of having internet radio on the HDX and also what is the best way to rip vinyl.
regards,
Dev
Posted on: 11 January 2009 by james n
Can you elaborate ?
James
Posted on: 12 January 2009 by John R.
- HDCD decoding (due to the fact that the CD 5X, CDX 2, CDS 3 and CD 555 all support HDCD decoding via their PMD 200 digital filter I can imagine that there are quite a few Naimees around who collected some HDCDs).And as far as I know the HDX runs with Windows and Microsoft is the owner of HDCD liscense...
- different digital filter modes to choose from... like Ayre or T+A.
- A way to copy the ripped WAV files from the HDX to another hard drive in the network. Although my HDX is very new and I expect it to work quite a few years, I would like to have my stored music as future proof as possible meaning that I can use my WAV files in ten or twelve years with other components (even non-Naim),too. This is because I do not want to rip all my CDs again and I have very strong concerns that there will be no CD drives around anymore in a few years. My point is that once the CDs are ripped to WAV files I can easily store them on whatever storage we will have in the future. This is a very important point for me. Besides that the internal ripping engine is at least as good as using EAC in secure mode with a Plextor Plexwriter Premium 2. For me there is no need to improve the ripping engine of the HDX. It is even that good that I would use it in order to rip to an external NAS instead of using my Plextor with EAC.
- Although the sound quality of internet radio is rather poor I would like to listen to it because of the great music they play.
- a "screensaver" for the touchscreen turns it off after a few seconds. When listening to music I do not want to see the album cover. It is a little like turning off the green button lights of the pre.
- quieter running internal hard drive
Posted on: 12 January 2009 by Rockingdoc
Originally posted by Dev B:
on the HDX what is the best way to rip vinyl.
regards,
Dev
Yes, pre-launch, my dealer certainly had the impression that this was on the cards for later HDX models, and I've been waiting for it to appear. Has the "recession" put this on hold?
Posted on: 12 January 2009 by SC
Am I wrong in thinking this was possible ? I thought you could go into the browser and move files away from the internal HD ? If not, what happens when the 400Gb gets full ? (Apologies if I've just asked a daft question!)
Up to now you can only rip CDs to the internal hard drive which is 400Gb - should be enough for about 600 albums.
As far as I know the upcoming software update will enable the user to rip CDs with the HDX to external NAS hard drives - offering more than enough storage. This is not to be confounded with exporting already ripped files.
Posted on: 12 January 2009 by Hans Vereecken
Originally posted by james n:
[QUOTE] I've already experienced that EAC easily outperformes the ripping engine from the HDX.
Can you elaborate ?
I bought a CD from Moby (Go - Very Best of). Brand new. Ripped it with the HDX. Second number was completely corrupt. Played the CD with a PC and could not hear anything. Ripped it with EAC. EAC struggled hard on the second number, but worked it's way through it. Copied the files on a NAS and played the second number without any problems.
Posted on: 13 January 2009 by Macker
Can you elaborate ?
Yip - that proved it alright....1 track on 1 CD proves without a doubt that EAC is a superior ripper to the HDX ripper...
Roll Eyes
I would take the CD back regardless and get a replacement...obviously faulty
Posted on: 13 January 2009 by paremus
Actually it only takes one such example.
Hans - assuming this is repeatable - would it be worth sending the problematic CD to the Naim engineers? Most be some unusual set of circumstances that cause this.
Just a thought.
Posted on: 13 January 2009 by Gary S.
I'm note sure if it's relevant to the above comments, but I have so far ripped 500+ CDs to my Nas drive, mostly using DBpoweramp. For some reason I have had a problem with a handfull of CDs.
I have tried various things to overcome and have found that some will rip using EAC, in one case I was able to rip using a different computer and some will rip if you make a CDR copy and then rip the copy. There's usually a way round it.
How do you take back a CD you might have bought 10 years ago and plays perfectly on a CD player?
Gary
Posted on: 13 January 2009 by David Dever
It may have been remastered nonetheless. Also–if the disc is not "truly" a Red Book CD (by way of disc corruption / copy protection schemes), you may have legal recourse in your jurisdiction.
Posted on: 13 January 2009 by Paul Stephenson
Hans it would be interesting for us to test the cd, do you know if its copy protected, this can sometimes cause an issue with some drives, perhaps ours? would be good to know. Often record companies will replace these discs for non-protected versions.
Posted on: 14 January 2009 by John R.
Up to now I did not experience any problems ripping copy protected CDs.
Posted on: 14 January 2009 by Hans Vereecken
I can not see any mention of copy protection on the disc. However, there is a special feature on the disc. It's is called "Opendisc". When put in a PC, it opens all sorts of extra info about the artist.
I've deleted the disc from the HDX and re-ripped it (with the HDX). The second song still remains buggy, but DIFFERENT then the first time.
I will send you the disc. I think, it will arrive next week.
Can you elaborate ?
Roll Eyes
Yes, normally that's the first I would do. But, when playing on a PC, I could not hear anything. Try to explain this to the vendor.....
Posted on: 14 January 2009 by Claus-Thoegersen
Interesting with this open cd thing I thought it was only something that plagued blueray and maybe dvd disks! for sure this must take the cd way beyond the redbook standard.
When I had the HDX on a long demo I found one disk a burnt copy of K.D. Lang Drag, from 1997 so it should be long before copy protection was added to disks. The HDX did nothing with the disk, I do not think the rip started at all. but my x2 and s3 play the disk without any problems. I will try to remember to bring the disk to my dealer and have them look for any error messages that may be on the frontpanel.
Claus
Posted on: 14 January 2009 by joe90
It must have realised that it was k.d. lang and it tried to save you from your fate.
You can almost hear the device screaming 'Don't do it Claus, you're a young man!'
Posted on: 15 January 2009 by Hans Vereecken
I did send the CD to Salisbury. It will arrive next week. Success.
The faulty track was number 2.
Posted on: 16 January 2009 by SC
Apple Lossless compatibility please.
Posted on: 17 January 2009 by jon h
Apple lossless is probably a deal breaker for me too
Posted on: 17 January 2009 by Paul Stephenson
Hans, thanks, Sc and Jon should be in next release 1.4d in beta right now.
oh dear :-)
time to tell Dr Peter to sell me on then lol. And more fraim. And...
Posted on: 17 January 2009 by SC
Great news Paul!...Damn! Winker
Posted on: 19 January 2009 by Paul Stephenson
HANS,disc recieved great thanks can you mail me with the following
current software version
- The unit serial number
Paul.stephenson@naimaudio.com
