Naim 135. Driving DMS Isobariks
Posted by: raymond on 26 February 2002
Further to my earlier question, would buying a 135 solve my problem. " Better Bass, Meridian 205 mono blocs". Ray.
Posted on: 26 February 2002 by Tim Danaher
even though I don't know what your original question was, I can state that 135s and Isobariks are a superb combination -- especially if you like deep, controlled bass. The Isobariks have to be carefully set up: good stands and surface.
Martin Payne also mentioned the possibility of driving DMSs (86-89 vintage, I think) using two passive 250s. These DMSs had two identical crossovers -- one for the three front-facing drivers, one for the the two upward-firing and internal bass drivers. This creates a much easier load for the 250s. Do a search for the topic 'PMS 'briks and crossovers'
Tim
Posted on: 26 February 2002 by ken c
PMS and DMS
whats the difference?
PMS - professional monitor system (active)
DMS - domestic monitor system (passive, which is what you need for your 135's)
best bariks are, i believe beyond 1985 or so vintage. see tony lonorgans website for series numbers etc.. cant remember the address, but may be on tony's profile.
else do a search
enjoy
ken
Posted on: 26 February 2002 by Jez Quigley
There is also the thread 'best briks' to look at.
Posted on: 27 February 2002 by raymond
Thanks Jez.
