Sky HD is rubbish - especially if you are in Spain
Posted by: DJ on 03 June 2007
I live in Spain and get good quality "Freeview" via a Pace Sky digibox and a 1.3 meter dish. I don't want to pay a Sky subscription.
Is it worth getting a Pace or Humax HD box if necessary with Dragon CAM / C.I. Module? Has anyone any experience of either?
Thanks David
Posted on: 04 June 2007 by Former member
You dont need a cam/module to get the BBC HD chan its programmed into the Humax and the pace. If you want to use your sky card in the humax you will need a cam ,you cant get sky HD Without getting it from sky.You can pick up lots and lots of chan's with the dish you have but you will need a motor.There are lots of things you can do with cams/ci modules ,you will have to look on the internet for that.
