How to connect NDAC to HTPC?
Posted by: Mike. G on 25 November 2010
Hi,
I've recently auditioned the Naim Dac with a Black Rhodia Rondo Digital Cable in my Hifi system. Overall I like it, highs were more detailed and bottom end has more definition and more extended, except I did think that the midrange, voices particularly were sucked in a bit.
My dealer said that this is down to the digital Interconnect and that if I used a better cable, I would get better results.
I plan on getting the NDAC, but, I'm not sure what to do interconnect wise, as I eventually want to build a purpose made PC just for Audio only. I was thinking of using an Asus STX Soundcard and using a Digital cable to connect to the DAC.
Interconnect wise I was thinking of Cleareraudio Silverline Optimum and use this between CD player and then computer at a later stage.
I'm no money bags so I only want to make a decent purchase once. I'm not sure on what is the best long term method to connect my CD player / computer to the NDAC.
Naim say I should use somthing like an M Aduio USB Soundcard and connect Optically, but If I get a decent sound card, will this help to ensure that if I connect using coax, that less electronic noisy interferance is sent to the NDAC?
Or I'm I better off long term, buying a decent optical interconnect and using this?
System is:
MF A3 CD Player
MF A1 FBP - Preamp
MF 550k Monoblocks
Interconnects - Nordost Red Dawn
Speaker cable 4x256strand speaker cable to each speaker
Audiovector Mi1 Sig's on Partington Dreadnaught Broadsides.
System is:
MF A3 CD Player
MF A1 FBP - Preamp
MF 550k Monoblocks
