flatcap or flatcap 2
Posted by: Nuno Baptista on 20 June 2003
What´s the difference?
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5
Posted on: 20 June 2003 by bjorne
Hi Nuno. Regarding sound quality I don't know. However, the flatcap can only power one unit where the flatcap2 can power both your cdplayer and your amp. So a question might be if 2 old flatcaps would be better than one flatcap2..... Upgrading is sometimes complicated. Are you buying new or 2nd hand?
Posted on: 20 June 2003 by herm
Hi Nuno. If you're looking for a PSU for your current sistem, the obvious choice would be the FC2! It will power both the Nait and the source! so think of the sistem sinergy - they are all of the same generation!
Herman
Herman
Herm. The cost of a new flatcap2 is maybe equal to 2 old flatcaps? What would be better in Nunos SISTEM? And as a former owner of a flatcap I must say it might be better to get a hicap or two from the beginning.
Posted on: 20 June 2003 by Greg Beatty
Just added a FlatCap2 to my Nait 5 last week.
Wow!!! I'm now hearing instruments I didn't know where there before and the sistem can be played louder and stays clean.
- GregB
Insert Witty Signature Line Here
- GregB
