Originally posted by Barratt:
I have just purchased a second had Snaxo 3-6 to replace the Linn outboard passive Isobarik x-overs. I have a 2 Hi-cap powered 82 and I am going to place the Snaxo in line to feed 6-135's.
...which you just happened to have lying around!
Question 1: Do I need a third Hicap to power the Snaxo or does it receive signal AND power from the existing 2-hicap/82 combo?
Third HiCap will be required. Short term, you could nick one of the 82 ones, I guess!
Question 2: The previous owner states the Snaxo has not been adjusted from factory settings. In most cases is this factory setting "best" for the Isobariks and thus myself?
Vimal is quite correct, the SNAXO is available in several slightly different versions (for Isobariks, NBLs, DBLs, Neat Ultimatums, etc, etc). Presuming it is actually an Isobarik SNAXO then the flat settings should be fine. Probably a very similar balance to the passive crossover you were using.
Call NANA (if sourced from the USA), or Naim UK, and quote the serial number. They can tell from their records how it's configured. Contact details on the websites.
If you open it up, you should see small markers drawn on the adjustment pots to show the factory default settings (which are set by measurement, so could be different for two different XO's, or even different for the two channels).
If you do ultimately find you want to adjust the levels you will need to make very small changes to the pots.
cheers, Martin
