confused
Posted by: rafizi on 10 August 2003
hi guys, i'm currently using an arcam alpha 6, 62+140 & mission 761 bookshelf. my room is around 22' by 18'. say that if i have around GBP1200 to spend, which item should i upgrade first? thanx.
Posted on: 10 August 2003 by Emil F
I'm confused too. There is a CD3.5 in your profile.
What's the story?
Emil
Posted on: 10 August 2003 by mathew farley
I'm sure most people would agree that a secondhand Naim cd 3.5 would be a good start, they go for about £500 to £650 give or take a bit + it can be upgraded with a flatcap or Hi-cap power supply.
As for speakers, that's a bit more of a personal thing. If you want to stick with standmounts the Mark 2 Linn Kan's are popular (Not much depth in the bass but fast and fun) Epos es 11's are also popular but can be a bit boomy in the bass.
I've read somewhere that the newer epos m12's have a more accurate bass but can't confirm this
Posted on: 11 August 2003 by rafizi
What's the story?
Emil
hi emil.... actually i used to have a cd 3.5 but then due to a financial difficulties, i had to let it go. i was going without a cd player for about 2 years+ and when i finally financially stable... i just settled for an arcam alpha 6. i got the player cheap though.. around GBP150.00 by that time second hand cd 3.5 are scarce & cd 5 is rather expensive.
Posted on: 11 August 2003 by Emil F
And now you have money for a CD5 or a s/h CDX.
Emil
Posted on: 11 August 2003 by Phil Barry
Hicap, used rega P3, lots of LPs? Well, definitely a hicap....
Regards.
Phil
