Hardwood Floors, spikes etc.
Posted by: Peter Stockwell on 18 September 2001
I'll be moving to a very nice hardwood floored room soon, and I don't want to have spike holes everything. I've seen Vuk's carriage bolt gizmos, is there anything like this ready made ?
Does anybody have a definitive answer ?
Peter
Anyhoo it completly robbed my speakers of bass, to such an extent even my girlfriend remarked, I promptly removed them and went back to the 2ps, with the added benifit of making it easy to push the spikes to move the speakers around on the wood floor. Mind you i have that pretend wood stuff so it slides real easy.
Furthermore, the floor must have room to spread laterally -- the instructions say 15mm across the width (perpendicular to the board runs), if memory serves. So be careful about bolting through it.
I have found the 1 or 2p solution the best, and I am not all overly concerned with strident/forward base.
Another point, if you need to run leads around the skirting, I use plastic electrical conduit with a rectangular profile (you may have already have wood moulding?) -- it finishes very well once the capping is put back on and covers the expansion gap very nicely indeed.
PH
No bolting through floors just looking for an effective spike replacement.
My mate Bruce in New Hampshire is very pleased with the ball footer arrangement, but I don't have much time to go searching for the materials while building up to the move.
Peter
Am I right in assuming that the carriage bolts are threaded in to the spike seatings, and the round profiles then sit on the penny coins on the floor?
Or are you going to create a whole new structure per Mike Hanson's diagram, per his post under the 'It's the room' banner?
Can you advise?
I have heard of people sinking Philips screws in to floorboards and then sitting their spikes on them i.e. in to the tiny recess in the head.
PH
[This message was edited by pholland on WEDNESDAY 19 September 2001 at 22:41.]
