does anyone know the explanation
Posted by: Arye_Gur on 08 April 2003
why the order of connecting the stereo pieces to the electricity in an array of sockets does matter?
Arye
[This message was edited by Arye_Gur on TUESDAY 08 April 2003 at 20:43.]
Posted on: 08 April 2003 by Paul Ranson
Yes.
Paul
Posted on: 08 April 2003 by Tarquin Maynard - Portly
No
Mike
Posted on: 08 April 2003 by markcas
no, get a grahams hydra Wink
Mark
Found this:
Outlet order
Posted on: 08 April 2003 by Arye_Gur
Originally posted by Paul Ranson:
Yes.
Paul
Paul,
Feel free to teach me.
Thanks in advance.
markcas ,
Thanks for the site,
I didn't find there a clear technical explanation (if there is any).
Arye
Posted on: 09 April 2003 by Paul Ranson
Humans are very susceptible to suggestion and even more prone to insecurity. If you have confidence you've set your system up better, perhaps by having considered the plug order, then it will sound better.
Paul
Posted on: 09 April 2003 by bruce
Arrggh ...
Posted on: 10 April 2003 by graphoman
“why the order of connecting the stereo pieces to the electricity in an array of sockets does matter?”
Leaving aside the sceptics (who want to spare 15 minutes though it would be enough to percept it for anybody, including the policeman on the corner), I don’t think it’s against the low of Mother Nature. All I want is 5 billion (milliard) dollar for founding a team of the best physiks expert and I’m sure I’ll guarrante the result in 5 years or less. We’ll understand all of audio’s parameters.
Supposing the society don’t want to spend this sum for clearing up the basics of Hi-Fi, your query will be unanswered I’m afraid.
graphoman
Posted on: 10 April 2003 by Arye_Gur
graphoman,
I agree with you' I thought that maybe there is an explanation for this.
Arye
Posted on: 10 April 2003 by Paul Ranson
Arye,
Which order do you prefer?
Paul
Posted on: 11 April 2003 by Arye_Gur
Paul ,
Power amp, PS for pre and nac,cd.
But I didn't try it in another order.
I also didn't try to check if the cables are directional as I don't see any reason why not following Naim's instructions - and for the same reason I locate the PS 30 cm' from the pre and don't try to see if I can I locate it closer.
Arye
Posted on: 11 April 2003 by graphoman
“I agree with you' I thought that maybe there is an explanation for this.”
As usual, there used to be plenty of explanations only we can never now which does really meet the case.
On the other hand, the right order is: source comes first, amp comes last. For half a year or so I was not that sure, I’ve published my query (like you now) on the Forum and had debattes with some US comrads of us who were of the opposite opinion. However, I felt that they could not be right, and at the end I got a message from the Naim Headquartier. They ’ve told I was right.
Nevertheless, it’s a good training to try it for yourself.
graphoman
