Cleaning coffee makers
Posted by: Mick P on 16 October 2005
Chaps
I have had my Gaggia Classic for a couple of years. It is used daily and it is still working fine producing good coffee.
I have never descaled the thing and although we use a filter jug, Swindon is a hard water area.
Does anyone know how you clean the thing and can you use normal descaling powder used for kettles etc.
Mick
Mick
Posted on: 16 October 2005 by Stephen Tate
hi mick, try using descaling liquid instead of powder. be careful not boil it though.
regards.
regards.
Posted on: 16 October 2005 by Mick P
Stephen
But how do you do it. Do you pour descaler into the plastic tank and run it through as though you were making coffee.
Mick
Mick
Posted on: 16 October 2005 by Adam Meredith
My experience with a filter jug and kettle seems to be no scale build up.
If this is not so in Swindon - I believe Gaggia have specific advice.
For example: http://beau-port.co.uk/acatalog/Beau_Port_Home__GAGGIADESCALERPACK.html
I would say yes to that one, its very similar to descaling irons.
Be sure to flush through with plain water a couple of times afterwards.
regards.
regards.
Posted on: 16 October 2005 by Edo Engel
I also use the liquid and poor it into the machine, then run it through in a number of phases COLD. To remove grease, I use small tablets and a blind filter.
A good idea might also be to use mineral water (no gas, obviously). Just get the cheapest stuff you can get, it will always work better than tap water.
Edo
Edo
Posted on: 16 October 2005 by Martin D
Do a search here for "water" "scale" as ya do
Posted on: 16 October 2005 by RiNo
Hi Mick
Do follow Gaggias suggestion as to descale the Classic (I have got one too). Every third month use Gaggias descaler and follow the process.
As Edo states, using bottled water (no gas) is a no brainer
Rickard
Rickard
Rickard
I will be contacting Gaggia on Tuesday.
Mick
Mick
Posted on: 16 October 2005 by Nime
Filter jugs have no apparent effect on the hardness in our water. The Management complained only yesterday about the hardness scum floating on the surface of the water in the jug, the scale build up on the glass and the algal bloom. All this despite frequent hand washing with washing-up liquid. (Ecover) Our jug sits in a sunny window.
Has anybody had any success with a magnet on the plumbing? The Management seems keen on the idea but the scientific debate goes on as to efficacy....?
The damn things aren't exactly cheap and I'm not much one for voodoo. Even if it comes in a brightly coloured plastic case to hide the paltry magnets within.
Posted on: 16 October 2005 by long-time-dead
The magnet idea has been bandied around the marine fishkeeping circles for a while. IMO it doesn't work.
Best thing you could consider using is a water de-ionizer. It will remove all the chloramine and dissolved compounds in the water. You will need to monitor the output to ensure that the TDS is as low as possible. Resin cartridges are refillable.
You may also want to consider Reverse Osmosis.
Is it legal?
Of course it is - water pollution isn't but they seem to get away with it .........
Why do they always blame the fish?
Posted on: 16 October 2005 by John K R
Mick, What you need is Gaggias own "baby cleaner" dont worry about the name, it is the right stuff. Sold in packs of three about a fiver I think.
see HERE for details. Click on prices at top of page and then de-scaling on the red bar near top. you can purchase here as well if you cannot find it localy,
John.
John.
Posted on: 17 October 2005 by Edo Engel
quote:Has anybody had any success with a magnet on the plumbing? The Management seems keen on the idea but the scientific debate goes on as to efficacy....?
We have... in the sense that it keeps the wife's mind at ease because she thinks it works, which isn't altogether true.
Edo
Posted on: 17 October 2005 by Nime
Edo
Well it's a plan...
Posted on: 20 October 2005 by Mick P
Chaps
Just a quick note to thank you for your advice and to let you know that I have ordered some cleaner from Gaggia.
Once again many thanks
Mick
Mick
Posted on: 20 October 2005 by Edot
Acid or acid based cleaner for mineral deposits and alkaline cleaner for organic ones. So the reservoir and group head would need to be cleaned differently. There is a cleaner for the group head, I think it's called urnex that is used with a special blank filter basket. Flush well with water afterwards. You will find everything about coffee here:
http://www.coffeegeek.com/guides/dirtygrouphead
Posted on: 20 October 2005 by Will_Dias
Try here. Select the descaling clip. It's an on-line instructional video, it's for a different Gaggia model, but the process is the same for the Gaggia Classic.
Will.
Will.
Posted on: 21 October 2005 by Nime
Why didn't he just break the damn thing and claim for a nice new one on the contents insurance?
It's been done too many times before?
Posted on: 21 October 2005 by Steve Bull
Surely Mick has a butler to attend to trivia such as coffe-machine cleaning?
S
S
Posted on: 21 October 2005 by Deane F
Maybe he has Germaine Greer in a cupboard under the stairs...
Posted on: 22 October 2005 by long-time-dead
Doubt it. She would have burned him at the stake before now .......
