ibl loudspeaker:
Frequency response: 45khz -- 2.khz +/- 3db (in room)
Sensitivity: 86.5db/W/1m
Impedance: 6 ohms (min)
Power handling: 65w (music programme)
Finishes: Black Ash & Walnut
Size (H x W x D): 800 x 250 x 277mm
The dimensions will probably include the spiked base, which is slightly deeper & wider than than the cabinet, so the they will look narrower than the dimensions imply. The depth at the top is also probably about half the figure above, because of the tapering front panel. It tapers all the way down to the base, ie the front face doesn't go vertical like the SBL.
Probably more music per square inch of footprint than virtually anything available today. Don't hesitate!
Best;
Mark
(an imperfect
forum environment is
better than none)
