Help required with DIY power supply for 32.5, 42.5.
Posted by: raymond on 06 July 2002
I am intending to construct a power supply to power a 32.5 pre-amp, I know that buying a Naim power supply is the correct way to tackle the problem but limited funds don't allow for this hence DIY. I have a 300va toroidal with 2x25 volt secondaries, 2 x 25amp 200volt bridge rectifiers and smoothing caps. I have been told that the 32.5 needs 2 x 24volt supplies, is this correct? How do I obtain this from one toroidal ,how does one wire the transformer to arrive with 2 separate supplies? Any guidance will be most appreciated. Regards, Raymond.
P.S. I will not be using the 32.5 with a Naim power amplifier.
[This message was edited by raymond on SATURDAY 06 July 2002 at 13:09.]
[This message was edited by raymond on SATURDAY 06 July 2002 at 18:14.]
