HELP : my 140 is quite hot even when no music played
Posted by: Ken Chang on 19 December 2001
However I noticed that all of it feel cold (room temperature) except the 140 which is quite too warm (hot) either played or not.
Is there anything wrong with it ?
One way to determine this would be to disconnect the speaker cabling and see if the amp still gets as hot.
Andy
from answers above can i assume that my 140 is ok ?
Hope this helps,
"Sans la musique la vie serait une erreur"
My 140 is fairly warm (not hot) when not playing music, and warm when playing music.So if your 140
gets really hot there might be a problem ,wich can be solved by your dealer or Naim.
Regards,Rob.
With no signal, it should not be hot. Take it to your dealer for a checkup.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
4 small resistors are driven hardly, at idle they produce more heat than output transistors.
The output transistors has to be checked and the bias adjusted if you feel it is too hot.
Emmanuel
Jan Erik, your Nait3 is ready.
