16 or 24 bit setting when using nDAC?
Posted by: James L on 28 May 2010
Hi All
AIFF CD rips > MacBook Pro (itunes) > Optical > nDAC
In the Audio Midi settings, do I use 16 or 24 bit setting?
24bit should be used if you wish to use the Mac Book volume control? Otherwise it doesn't matter?
BTW, this nDAC is a.w.e.s.o.m.e!
TIA.
ATB.
Posted on: 28 May 2010 by James L
Doh. Maybe this should be in Distributed Audio...
Posted on: 28 May 2010 by james n
Set at 24 bit. Sounded better (and no i wasnt using the volume control) than 16bit when i used to use the optical connection.
James
PS - and yes its only padding the remaining 7 bits with zeros...
Posted on: 28 May 2010 by PureHifi
Glad you are enjoying it James...
Thanks Bruce.
I'll ring in the next day or so... Actually it'll be Monday now as it's 5.40pm Saturday as I type this...
