Reset Nv-i Remote
Posted by: GJM on 06 January 2007
How do I reset the remote control unit. I ma getting no response, have changed batteries, so assume a reset is required.
Thanx
GJM
Posted on: 06 January 2007 by David Dever
There are two remote codes used for the n-Vi (AV and DVD), so you'll need to perform this operation twice using the supplied remote:
Press the white AV (or, DVD) button
Press and hold both OPEN and SUBT buttons. Then press the numeric 1 key.
The n-Vi display should flash a message to this effect.
Posted on: 06 January 2007 by AV@naim
I will try and get the full procedure added to the FAQ shortly
Posted on: 07 January 2007 by GJM
Thanx
Have now reset reomte, which is transmitting a signal, but no reaction form the Nv-i. Any suggestions?
Thanx
Garry
Posted on: 07 January 2007 by Mike1380
Errr,
Someone should have said that you need the n-Vi powered up, and aim the remote at it whilst doing this procedure.
Am guessing the n-Vi works ok from front panel operation???
Posted on: 07 January 2007 by AV@naim
Originally posted by Mike1380:
Errr,
No, there are two resets...
-one resets the remote itself (as per Dave Dever's post), which usually works 99% of the time.
-The other one requires the n-Vi on and the drawer open as well as the above, to reset both the n-vi and remote system codes.
I will arrange a post in the FAQ concerning both in due course
Posted on: 08 January 2007 by Adam Meredith
Just back from an extended holiday - http://forums.naim-audio.com/eve/forums?a=tpc&s=6701938...752995707#5752995707.
Posted on: 09 January 2007 by AV@naim
Adam,
link above is now dead, here is it re-posted
http://forums.naim-audio.com/eve/forums/a/tpc/f/3452929996/m/3882916707
