N-Vi Update upset!
Posted by: Toeknee on 20 February 2008
Hi All,
I hope you can help! I received the update for my N-Vi today from NAIM. I have followed the upgrade to the letter but now the picture has shifted and the volume bar when displaying on the screen drops down and the picture darkens and distorts!
I notice in another thread that forum member Margan had this problem and his dealer fixed it - is this something I can fix myself??
In the mean time I have left a message for Tom Tom audio who supplied me the unit.
Any suggestions a worried N-Vi owner
Confused
Posted on: 20 February 2008 by AV@naim
Dont panic!
-put unit on disc input, with no disc in drawer, drawer closed.
-press and hold the input button on the front panel for a couple of seconds, a Service Menu appears on the front panel
-go to Settings (second down) using the remote navi/ok keys
-select either Comp Offset.fix (or DVI Offset.fix, depending on firmware) with arrow keys and switch it on (if its off), ok the selection
-exit the Service Menu by pressing setup button breifly on remote control.
Is the picture properly aligned now?
Posted on: 20 February 2008 by Toeknee
Big Grin
Thanks Av@Naim it is working just fine now!
Phew - Panic over!
Posted on: 27 February 2008 by cafez27
Phewey Toeknee you sounded very worried, glad you got it sorted, how is the picture now?
