n-Vi operational problems
Posted by: Margan on 17 October 2006
Hello,
now that the power supply problems are solved (with my 5th n-Vi, some weeks ago), I would like to know about the fixing of the operational problems.
The most important ones for me are:
1. CD track selection: it is not possible to start a CD with a different track than 1: at least one or two seconds of the first track are ALWAYS played.
2. Repeat-Disc doesn't work at all for CDs, so I got problems playing-in (correct word?) my n-Vi (and my new SBL drivers).
I got the firmware version with the new progress-bar when switching on.
Posted on: 17 October 2006 by Former member
check out your menu settings.regards munch
Posted on: 17 October 2006 by AV@naim
Disc repeat has a known bug.
(should be exterminated on next release)
Posted on: 17 October 2006 by Margan
What do you mean? I don't know any menu settings regarding these two topics.
regards marc
