Nait-pre or 72?
Posted by: roach on 11 April 2003
Hi all,
Should I convert my nait back to an integrated so I'll get more cash for it, sell it, and buy a second hand 72?
Will the phono board fit in a 72?
Would it make a worthwhile difference?
Tony
Posted on: 11 April 2003 by NB
Tony,
In a word.. Yes.
A dedicated pre-amp is going to sound much better than a make-shift pre-amp.
The 72 was a pretty good pre-amp in its time and still sounds good.
What power amp are you partnering it with?
A 72/hi/180 is a very good amp to aim for.
NB
Posted on: 11 April 2003 by roach
NB,
It's a 140.
Tony
Tony,
The 140 will partner the 72 quite nicely. With the addition of a hi-cap you will have a very good amp.
NB
