French drains - British Standards?
Posted by: MontyW on 31 July 2005
Hi all,
Can anyone advise if there is a British Standard for french drains and if so where will I find it?
thanks,
Posted on: 01 August 2005 by Justyn
Posted on: 01 August 2005 by BigH47
Would that not be French Standard?
H
H,
"French Drains" is a generic term. A proper french drain is basically a trench infilled with gravel etc, and then turfed over. Their used to channel away moisture, and especially uslefull if your neighbours garden is higher than yours.
This link will give you a good insight.
http://landscaping.about.com/cs/lazylandscaping/ht/French_drains.htmJustyn.
Thanks Justyn never heard of them before.
Howard
Posted on: 01 August 2005 by MontyW
Thanks Justyn - very helpful information contained in the link.
Posted on: 01 August 2005 by Larry
