82 improvements??
Posted by: Matt worlock on 02 March 2001
Cheers for now Matt.
How exactly did you go about removing your boards ....I mean like where are they once the lids off...is it simple case of pulling them out of a slot & leaving them in draw or somthing?
I don't want to invalidate my guarantee.....do tell.
Matt.
To remove the boards, just undo the 4 feet, and the hex bolt. Then slide the tray out from the outer case. I prefer to push the tray from the back so that the facia is not pulled away from the front of the tray. Needless to say, do it slow and carefully to avoid damage.
It should be very easy to then remove the phono boards. Don't break the plastic mounting post. Make sure you can see that the fingers on that post are all inside the phono board hole before you try to lift up on the board.
Straight forward enough, but leave it to the experts (your dealer) if you have any doubts.
While you are there, you can check and see if there is a cable-tie on the wires above the volume and balance box. If so, you can remove it, with nail clippers, to audible benefit. Don't cut the wires or it's a service call.
Again watch the tray as you put it all back together. It would be a shame to end up with a scratched box, even if it sounds better than before. And don't overtighten the feet, they just need to be held against the base.
Simon
I was told by Naim the other day that I would have to send my 82 in to them for them to check if my volume speed could be adjusted or whether I would require a new part costing approx £150.
Based on your post I've just had a look myself and have successfully adjusted it, so you've saved me considerable time and inconvenience.
I can only assume the chap at Naim (sorry, don't know his name) had very little faith in me, as I did ask if it was possible to check myself which of the above alternatives would be necessary, and was told it wasn't.
In fairness the chap was otherwise very helpful, taking my details and telephoning me back the next day when he had found out the answer, but in hindsight I am now a little surprised at his advice
Knowing my luck there will now be a post from Naim saying "whatever you do, don't touch the small screw behind the volume control", but it does seem to have done the trick.
Anyway, thanks again Juan!
Ade
There is a printed circuit board immediately behind the volume/balance controls and running from this board to the left is several small wires held together with a cable-tie. You need to very carefully snip this cable-tie, and once removed, seperate the wires so they are spread out a little above the circuit board.
Ensure that the wires will not be touching the casing on re-assembly, and replace the tray into the casing before replacing the bolt and feet.
Hope this helps
Ade
Ps
I gather Naim actually manufacture the 82 like this now, so it only applies to 82's before a certain age
I can't agree with Russ that adding a 2nd Hicap is a subtle change. I found it one of the biggest upgrades in sound quality I ever made!
I do agree with him, however, that the cable clipping is subtle, but very worthwhile. It's not so subtle that you wonder if there's really a difference - you hear the change immediately.
Henry
Did the phono boards removal thing and...........
it was straight forward & easy to do just as you explained. The results of which has had me listening closely.... or at least I thought I would have to...... but what a pleasant surprise the soundstage opened up & separation improved quite alot in fact I started to understand what all this PRAT thing is about. I was suitably impressed.... a lovely little tweak!!!
Thank you
If you have any more ideas just let me know!
PS. I didn't have to clip the cable tie... it wasn't their so i quess Ade Archer bloke was right about new 82'S!!
BYEEEE MAD MATT.
