I have a 1996 pair of Credo with the crossover inside the speaker. Sould i bother to change it for the newer one that goes outside?
Bernard Paquet
Posted on: 26 September 2001 by garyi
See if you can get a second hand pair pf Paxos, they are better.
Posted on: 26 September 2001 by Manu
Yes , Bernard go active, you can find a used NAXO 2/4 for <500$CAN. Supply it with one of your SNAPS (if you still have...) and don't bother with a passive xover. I did not forget your demo disk, no more in stock. A Naim container arrived yesterday.
