Questions from a Hi-fi virgin and a new member to the Naim family
Posted by: monkeboy on 12 May 2001
Hi All,
Have been lurking the boards and must say thanks for all the information, it's been a great read.
Well I've finally gone and done it. I've bought my first hi-fi system and I'm happy to say Naim is part of it.
System as follows:
Naim Nait 5
Arcam CD72
KEF Q55.2
Chord Chrysalis interconnects
Nac A5 speaker wire
I demoed and auditioned other components and nothing came close to the above kit, and that which did cost a hell of a lot more and was seriously over my budget. I shopped around, bartered and managed to get change from £1500 on the above system. To say I was happy is a serious understatement! big grin
Anyway after getting home and excitedly setting up my system, I started spinning discs. My questions are:
1. what's the best way to run in a system?
2. how do I get the most out of my system?
3. how do I keep my system in its best shape, and
4. any suggestions/hints/tips for in the up keep and maintenance of my system.
So far I've left my amp and cd player on since I've set the system up. I've been playing the system at various volumes from soft/moderate to around 1 o'clock on the amp. The only thing so far that I'm corncerned with is that when I connected the speakers, I found that the clip for the positive(black) doesn't extend as far into the speaker termination plug as that of the negative clip - the negative terminal fits alot more snuggly into the speaker plug. When I shifted the speakers I found the (+)plug would come out quite easily. I also put this down a little to the inflexibility of Nac A5 speaker wire.
With the Naim speaker termination plugs that connect directly to the amp are the speaker wires supposed to point down or up from the connected speaker plugs?
Anyway thanks for reading and any help/suggestions/tips/guidance will be much appreciated.
cheers
t.
Posted on: 13 May 2001 by Mike Hanson
To break it in, just play it. Louder is better than softer, at least for the speakers (to "loosen them up"). The speaker plugs are designed to point down, although it doesn't really matter as long as the polarity is correct. In other words, some people don't like them pointing down, so they get them soldered so that they point up.
-=> Mike Hanson <=-
Posted on: 13 May 2001 by Sproggle
Erm... I hope you don't mind my pointing this out but wouldn't it be simpler just to swap left and right speaker cables? smile
--Jeremy
Yup, that would do it. I hadn't fully thought it out, obviously.
-=> Mike Hanson <=-
Posted on: 14 May 2001 by Rico
Not too loud to start with - for instance, if you left Nirvana's Nevermind playing unattended all weekend at high volume, you might just find a big heat buildup in your new driver....
Moderate to start with, something with a good full range of sounds (eg not just a nasal singer songwriter with a banjo)... after a weekend, give it some more welly, heavier rockier stuff... and then go onto your Drum & Bass stuff... now you're ready for Nirvana.
If you're really impatient, place the two speakers facing each other, about 6-8" apart. Connect one speaker out of phase, play music for a weekend. Place a duvet over the top of this assembly - should be fairly quiet. Oh, don't forget the mono button.
Time for speakers to break in varies greatly, electronics have both 'burn in' time, and 'warm-up time' - this also varies. YMMV.
Rico - all your base are belong to us.
