Which mains distribution block?
Posted by: Steve C 01 on 18 July 2001
I'm looking for alternatives to Music Works (good but expensive) and Russ Andrews (expensive and expensive and split opinion)...
Cheers in advance...
Steve C 01
The Olson block uses filtering, so most Naim users would not recommend them, RA unit is the same.
Personally I took a trip to the local electrical wholesaler, and ordered some 15A plugs and sockets. The contact area isn't much better than 13A, but they are unfused, removing two contacts and a fuse from each plug.
Attach the above to a suitable backing board, and wire them up with chunky cable. I managed to star-wire the 4 sockets I have, which means there's little difference which socket I use for each component.
Attach some chunky 15A flex, along with a suitable mains plug to suit the wall socket (Crabtree / MK) and enjoy. If it's a single socket on the wall, changing that for a 15A type will improve matters too, although you'll lose the fuse, which means you need to be very sure of the constructional quality in your block.
My one is a massive improvement on any of the cheap multi-way blocks, you can still save for a Musicworks block in the meantime, I've yet to compare one to my own setup, as I'm more than happy with it.
You could also try the 4 into 1 plug that is available from some DIY outlets and Maplin etc. This allows hard wiring of 4 cables into a single 13A plug - it's not bad for the money.
Andy.
Andrew L. Weekes
Spend 225 quid on a mains block which will make an equally significant improvement?
Oh, no! Too expensive!!
Some people!
It's always a nice day for it, have a good one ![]()
Steve
It also takes up less room than a 4 way adapter.
Jonathan
There's no point in skimpin' and savin'
Unless that is one can get more 80% of the performance for less than 20% of the cost ![]()
Andy.
Andrew L. Weekes
Steve
Looking forward to meeting a number of youi at the Barbie!!
