352.8khz/32bit
Posted by: Occean on 28 September 2009
Its getting silly
FIM (first impression music) have just made some silly high resolution tracks available for FREE download
Now....can anyone actually play that back?
Posted on: 28 September 2009 by Patrick F
naim dac.
Posted on: 28 September 2009 by Klout10
Does the HDX supports one of these formats?
Michel
no up to 192/24
naim dac via usb device 32bit/768k
Thanks!
Posted on: 29 September 2009 by noname
Originally posted by Patrick F:
no up to 192/24
But how can you select files to play from the USB device when there is no front panel display on the DAC?
Posted on: 29 September 2009 by DaveBk
Just like an iPod shuffle. The tracks are ordered alphabetically and it plays the root directory first then searches each subdirectory and each track within those.
Posted on: 01 October 2009 by Hans Vereecken
Originally posted by Occean:
Its getting silly
Can you provide me the link for this?
Posted on: 01 October 2009 by Eloise
Not sure if they are elsewhere too, but if you search for the Computer Audiophile forum / website the FIM files are the first item on the front page.
Eloise
Posted on: 01 October 2009 by garyi
Is it god awful plinky plonk musak?
You can't polish a turd no matter how high res it is.
Posted on: 02 October 2009 by Klout10
Yes it is, I've tried it...
Michel
Posted on: 02 October 2009 by Eloise
Possibly ... but it's free ... and will work to demo/test the high res capability.
Eloise
Posted on: 02 October 2009 by DHT
Eloise Hi, I thought that the highest res files currently available were 358.2 ? And that you could only play those if you had an ax24 dac (digital audio denmark ) and only then through their own digital workstation?
I don't know for sure - but think in WAV format, these 32/352.8 (44.1 x8) should be playable from USB Memory stick with the Naim DAC.
Eloise
Eloise hi, does that mean the new ( Naim ) dac will just upsample to that frequency, or can it play native DXD files?
I think so ... if you look at the spec for the DAC it's says:-
Format: Audio files supported: USB = WAV (LPCM up to 768kHz / 32bit)
Which I think means that it will play WAV files upto 32bit and 768kHz from a memory stick.
Not 100% sure but it's on my list of DACs to audition when I get my new system (soon).
Eloise
Posted on: 06 October 2009 by mudwolf
oh, should I redo my Mac files to WAV and not aiff or lossless?
Posted on: 07 October 2009 by js
They'll all look the same at the dig out regardless of how they're stored so you're good.
