Uniti
Posted by: chris_p on 19 December 2009
My NaimUniti regularly requires a restart, using the rear rocker switch, when it fails to initialise an input following a pause in play.
The most common culprits are the iRadio and iPod n-link inputs.
The display goes into a loop and the Uniti will not play.
Selecting DAB or FM often returns the sound but reselecting the 'rogue' input results in the same loop and silence.
Any comments, suggestions or solutions welcome.
Posted on: 19 December 2009 by fathings cat
I haven't experienced that with mine - worth a chat with your dealer I guess.
Posted on: 19 December 2009 by Kane
The only problem that I had is with my network not the Uniti you need to talk to your dealer
ASAP.
