Equipment support thats not a fraim!
Posted by: Matt worlock on 12 April 2002
Hello all,
Look I know yer all gonna say the fraim is what I should go for but at about £2000.....you can forget it , I mean thats a xps for me cdx init!!!
So heres the other options please give me your thoughts on them.
Option: 1/ Sound organisation 5 tier
Mad Boy Matt
Posted on: 12 April 2002 by MarkyB
Matt,
I know it is expensive and can understand you point, however I could not believe the improvement my Fraim made to my system. Even the wife could not believe it.
M
Posted on: 12 April 2002 by JRHardee
Fraim was out of the question for me too, but I got a big improvement by moving my system off Target and onto a second-hand Mana rack. Getting my TT off a Sound Org table and onto a Mana one-tier was even bigger.
Posted on: 10 May 2003 by NB
Matt,
Check out the Apollo range, their cheap and cheerful but they do the job very well.
I used one to support my CDX/XPS 82/HI/180 for many years.
NB
Posted on: 10 May 2003 by Naimed-In-NY
I am very pleased with the Quadraspire Q4 stand. Although I'm sure it is not as good as the Fraim, the cost was very reasonable (a fraction of the Fraim), it is very attractive IMHO, and you can add additional shelves and specify the spacing between shelves.
Posted on: 10 May 2003 by Alex S.
Hutter would be a good choice, less Hostess than QS.
Alex
Posted on: 10 May 2003 by Mekon
I can't say that I found an enormous improvement in moving my amps off of a light wooden table onto a Sound Org rack. Clearly, any rack change has to overcome the effects of the gear being switched off, and AFAIC Sound Org doesn't hugely. The bass was a bit tighter, punchier, etc. I can only contrast this to people's description of changing to proper stands (hutter/fraim/Q4R/mana). The effect of such purchases are usually measured in terms of box upgrades, which clearly outrun the powerdown.
Posted on: 10 May 2003 by Steve Toy
The Quadraspire Reference is jaw-droppingly better than the standard Q4 and it's much cheaper than the Fraim.
4-tier plus runt shelf in black with silver rods should cost about £730.
Steve.
Posted on: 11 May 2003 by Mekon
Originally posted by J. A. Toon:
If, however, you mean that it makes evaluating the new rack within the time-limits of a trial demo more difficult, fair point. In that case I would agree with you; if it doesn't sound better despite being powered down, then it can't be that much better than what your equipment was previously on.
John.
_E-mail: john.toon@btinternet.com_
Sorry, I thought it would be obvious.
Posted on: 11 May 2003 by garyi
Indeed ash is a good rack well worth the money.
www.ashdesign.com
Posted on: 14 May 2003 by Matt worlock
Better late than never!
Purchased an Atacama equinox base plus three levels from a web based company. Sounds great & looks great so I,m happy.
Mad Boy Matt
Posted on: 14 May 2003 by Boz
moving from Sound Organisation metal/glass 5 tier rack to 1 x Q4,1 x Q4 ref and 1 x Q4 ref wall shelf in light oak/silver all being fitted tomorrow evening so I'll let you know how it sounds......
Posted on: 16 May 2003 by Boz
Installed last night.......
First impressions apart from that it all looks a million times better is that the QS Ref made a massive difference to my CDX/CDPS/82/2*hicap/250 set up but the Linn LP12 on the QS Ref wall shelf seemed fairly dull. It was on a simple IKEA Lack before so I was expecting a big leap in sound quality.
I'm sure this may change when all the gear warms up again I'll let you know.
