Naim DIN to XLR Question?
Posted by: General Skanky on 01 June 2005
How long a run is feasible from the AV2 to XLR connections for my active speakers pelase?
I ask as my original lead introduces loud hum on the spekaers on the 10m run. The 5m run is fine.
It was ok when it was RCA to XLR.
I suspect it's the cable, shielding etc not the best as it is a made up lead that I've used for a while that my dealer did.
I've tried swapping around but it is definately the 10m run at fault.
The best way to describe it is if it's a earth loop fault.
Thanks for any ideas.
I'll be talking again to my dealer anyway, but just thought I'd ask here.
Posted on: 03 June 2005 by Adam Meredith
I have had a word with the boffins and your dealer today.
Solution should be in hand.
Posted on: 03 June 2005 by General Skanky
Hello Adam.
Been there, and the resistor trick worked perfectly.
Thank you very much.
I am now hiss free.
Fantastic service all round. Very much appreciated.
