Alignment Protractor
Posted by: garyi on 13 July 2002
Folks. Has anyone got an linn LP12 alignment protractor suitable for the ittok they could send me.
I promise to look after it and send it straight back!
The one I download from Linn is in PDF so can't be adjusted and prints too small.
Thanks for anyones help.
Posted on: 13 July 2002 by MarkEJ
Gary, I presume you mean the one on the last page of Linn's Cartridge Dismount/Remount manual. Open it in Acro Reader, go to Page Setup, and set size to A4/100%. Then print and check result with ruler. Works fine with AcroReader 5.x, OSX 10.1.5 and HP LaserJet 2100 for me.
If still a problem, copy the protractor graphic out of the pdf, paste into AppleWorks drawing doc, and shift/resize in the normal way to ge the scale right. You can zoom right in to get it spot on, and print from there.
Best;
Mark
(an imperfect
forum environment is
better than none)
Posted on: 13 July 2002 by Paul Ranson
I've managed to print one accurately from XP (ha ha!) (to a network printer, did I have to find a driver disk? No!)
Anyway either check the boxes to make it print as file or send me your address and I'll stick this one in the post.
Paul
Posted on: 14 July 2002 by garyi
Cheers, I will check the settings when I get back home. It was printing about a third too small for me, but I must confess I was printing from 'Preview' not acrobat
If I still can't get it right Smudge I will take you up on the offer.
