Can Naim DAC with Squeezebox Duet match or better a CDX2?
Posted by: roo on 24 February 2010
Does a Naim DAC with Squeezebox Duet match or better a CDX2?
Posted on: 24 February 2010 by Asenna04
It is better in my experience.
Seach this forum for details.
ASenna04
Posted on: 24 February 2010 by Bouarb
That is exactly what I would like to know!!
And if I may ask a second question in addition:
Would the upgrade from a Squeezebox Duet to a Linn Majik DS be a big step (plizzz, say no Big Grin)
Euh, so sorry, but I couldn't find the details... Confused
Posted on: 24 February 2010 by JYOW
In my humble experience I was never happy with the Squeezebox connecting to different DACs, and I have used a few different DACs.
The Transporter however is a different animal.
YMMV etc.
Posted on: 24 February 2010 by themrock
I use my SB-Duett with the internal DAC of my SN, i like it very much, but i didnt compared it to the CDX2.I compared it to the CD5i and in my opinion the combination SN/SB was better than SN/CD5i.
My advice is to wait until you can buy the SB-Touch, because it should sound better than the much more expensive Transporter (said from Beta-testers in the Logitech-Forum) and second you dont need a computer,NAS etc to run it.
You can switch an ext. HD direct to the Touch and the Touch direct into your Amp.
Posted on: 25 February 2010 by AMA
In terms of electronic designs SB-Touch is WAY below TP in terms of bitstream quality.
In terms of implementation -- we shall see.
In terms of beta-testers opinions -- here is a excerpt from beta testers of Windows 95 : "Unlike it's predecessors Windows 95 features completely new kernel which allows absolutely stable operation" or "95 never falls down!".
Let's wait for device to show up and see what the end users say.
Posted on: 25 February 2010 by Asenna04
See these:
http://forums.naim-audio.com/e...122963927#3122963927
http://forums.naim-audio.com/e...132923627#9132923627
http://forums.naim-audio.com/e...572927417#4572927417
They are not on exactly your question but some posts will give you an idea about how good the DAC is with Squeezebox.
ASenna04
ASenna04
Now that is very interesting. Can you please direct me to where the beta testers have said this?
ASenna04
Posted on: 25 February 2010 by js
I'd wait at least until the touch to compare. An SB2 won't be there IMO. I think there's a bit too much 'better than' 'equal to' questions in general here, especially when comparing different formats. You really need to try these things for yourself and decide. Opinions here will vary quite a bit. Some decisions are usage driven and it's comforting to hear it's just as good. Others just like one thing better than another and don't care about format. Bring a SB2 to a Naim dealer if you need to and give a listen. I suspect most have both a CX2 and DAC on hand.
Posted on: 25 February 2010 by themrock
A direct link i cant give you.
I have read it in 2 forums.
a) in the german hifi-forum, there is a beta-teste.
b) in the
 http://forums.slimdevices.com/...a7bd98fcb4776fa&f=20
But i cant remember the threats, where i read it.
I found only this.
Touch versus Transporter - betatesters chime in please
> Have there been advances in the digital volume control on the new Touch
> to help with the problem of not losing resolution when running straight
> to amp? (I know there are pros and cons to preamp or no preamp)
What do you mean? If you lower the volume, you have to truncate bits.
Its a feature.
> Analog outputs.....is the Touch the equal of the Transporter or is the
> Transporter better.
I have not compared them, but those beta testers who have say that the
Touch is competitive. Since it is a lot less expensive, that may be good
enough for most folks.
The Touch does not have balanced outputs, which are handy if your amp
has balanced input.
Pat Farrell
http://www.pfarrell.com/
pfarrell
View Public Profile
Send a private message to pfarrell
Send email to pfarrell
Find all posts by pfarrell
Add pfarrell to Your Contacts
#3 2010-01-31, 17:11
JohnSwenson
Senior Member Join Date: Jun 2006
I don't have a transporter but have done a comparison on someone elses system with a transporter. I actually preferred the Touch. Its definitely going to be a personal thing, some will think the Touch sounds better, some the Transporter.
I really like John Swenson's posts. Can measure the differences very clearly between connectors and DIG cables and does talk about how much better the DIG out will be on the touch compared to a SB3. Apparently he's done a lot of work to quiet the included switching supply at the touch end anyway. Mentions about how the extra PS load of headphones really pulls down overall performance, how much a linear ps improves the SB3 etc. Apparently the processor in the touch will be substantially more powerful than the TP as you'd expect after this much time so that along with a better than expected PS may help it vs a TP. Of course the coax out is RCA instead of BNC so who knows? Frown We'll have to wait and see.
Posted on: 25 February 2010 by Bouarb
See these...
Thank you Razz
