Cosmetic Dentistry
Posted by: Rockingdoc on 06 September 2006
Vanity has got the better of me and am thinking of having the ageing yellow fangs done. Has anyone experience of; dental laminates, crowns or implants. I'm particularly interested in the "best thing I ever did, changed my life" or "absolute Hell, wish I'd never gone near it" variety before I take the (costly) plunge.
p.s. I'm not seeking medical advice
Posted on: 08 September 2006 by Rockingdoc
Blimey, 65 hits and you've all got your own teeth. Well done lads. I blame my 1950s Glasgow upbringing.
Posted on: 08 September 2006 by Beano
Unless they look a bit like these teeth I wouldn't bother and save yourself some moola.
Beano
Beano
Posted on: 08 September 2006 by Mick P
Rockingdoc
I have a crown in my front upper tooth.
I am a subcriber to denplan with covers some of the cost of having a crown fitted.
It costs about £500 per tooth less any subsidy and as you get older, your gums receed faster so you may need to replace it every 7 or 8 years.
The fitting is painless and you just forget all about once it is in.
I would go for it.
Mick
I would go for it.
Mick
Posted on: 08 September 2006 by Gunnar Jansson
Doc
I am a dentist with practice i Stockholm city.
Do a lot of cosmetic dentistry.
Don´t know if your seeking a reply from a professional or not.
Depending on the condition of the teeth in mind you shall always strive to use methods that are as less invasive as possible.
Try to keep the teeth as intact as possible.
If dental laminates is possible they are less aggressive to the tooth than crowns.
Just bleaching also can do wonders.
But as I said before, it all depends on the condition of the teeth you want to treat.
Sometimes crowns are the only alternative.
And if you treat front teeth make sure they are ceramic crowns with no underlying metal, preferable with bonding technique and bevels supragingival.
A close professional relationship dentist- dental technician is also vital for good colour/size matching.
/Gunnar
/Gunnar
Posted on: 08 September 2006 by David McN
I have about six crowns and a bridge. I also sibscribe to Denplan. Up here in t' North for a new crown on Denplan you pay the costs of making the crown, about £100 and a bridge about £300 - but it all depends on quality and it is certainly better going for the better quality products. Even then they do have shelf life and 10 years is good. I should add that all my crowns have been judged clinically necessary by my dentist and were not 'vanity' treatments.
Posted on: 08 September 2006 by Stephen B
Can't it be done on the Gnashional elf.
Posted on: 08 September 2006 by jayd
Lemme guess... Shane McGowan?
Posted on: 11 September 2006 by Rockingdoc
Thanks chaps. I have an initial consultation this afternoon. I'll bear your advice in mind.
Posted on: 13 September 2006 by markfs
Got to be Mcgowan's burnt-out fusebox of a mouth, for sure. Now all removed.
Guess it would have been a bit late for a jolly good flossing, would probably have bled to death anyway!
My dad had to have a few new teeth fitted a few years ago, synthetic teeth with gold screws!
Nice little pilot hole drilled into the gum/jaw and then simply twisted in.
OOOUUUUUUUUCCCCHHHHHHHHHH !!!!!!!!
Posted on: 14 September 2006 by Rockingdoc
I've had my initial consultation, with many many photos and x-rays. Been convinced that laminates are the way to go for me. Cheers.
