AV2 Signal Loss
Posted by: wobrenton on 17 January 2007
My AV2 does not hold the DVD or TV signal (from the cable box) when switched on from the dark mode. I have to power down the AV2 and let it reset, then it picks up the signal. Has anyone had a similar problem, and if so is it fixable?
Thx,
Bill
Posted on: 17 January 2007 by john R1
perhaps its coming out in sympathy with the n-vi
Posted on: 18 January 2007 by Roy Donaldson
What software version is running on your AV2 ?
Roy.
Posted on: 18 January 2007 by wobrenton
Not sure. How do I check?
Figured it out. Software is AVCO106 F658. Do you know if this is the latest version?
Posted on: 18 January 2007 by David Dever
AVc01-07/F658 is most recent.
Posted on: 19 January 2007 by AV@naim
-Are you getting 3 flashing bars and no audio?
-I assume that you are running optical or coax rather than analogue?
if so try the other coax/optical inputs. Do they work?
-Are the cables fitted securely
Posted on: 19 January 2007 by SimonJ
I used to have exactly the same problem, when my AV2 was fed Sky via Panasonic DVD HDD recorder via DVDO scaler, never when fed direct from the DVD5. I somehow think that the DVDO messed around with the signal a bit in such a way that the AV2 took offence to. I noticed that if Sky was powered off and the AV2 had not been fed a signal for a long period of time, even though the Panasonic HDD and DVDO were still on, then it would do this and I would have to power cycle to bring it back. If I leave Sky on all the time, then no problem.
