Speaker, Spikes and Wooden Floors
Posted by: uem on 04 March 2001
Some weeks in a thread in this forum someone mentioned the problem of speaker, spikes on wooden floors. One option mentioned was using a concrete slab or tile that was then fixed with “blue tac” or something along these lines…)
What is blue tac ? (Sorry, being Swiss may explain my question…!)
Does anyone have alternative experiences with speaker, spikes on wooden floors?
Thanks for your feedback
Urs
My speakers are Wilson Benesch ACT 1 (Not NAIM, but at least British !!)
Matthew
As this appears to be some kind of glue, I guess I need to persue other alternatives of speaker support, since I want to be able to move/slide them around occasionally (and still have some sort of "coupling effect" of the spikes).
Urs
It's not exactly glue, it's a kind of gum. If you do a search on author "Thomas Kunzler" and title "Blu Tak" you will find an explanation in German, might help you a bit more.
In Dutch they are called "Buddies" and nowadays they are white. When I was young they were pink and impossible to remove completely from the wall. You could always spot where "buddies" were used to stick a poster to the wall because of the pink spots!
Ciao!
Willem
In the U.K. Blue-TaK is more likely to be sold in stationers stores,the type of shop selling pens,pencils,rulers,paper clips and so on.
Chris
p.s. If you still can't find any,then I suggest that you take Jonathan up on his kind offer
(...Camping season approaching...getting itchy feet for 'Aptrick
I'm going to remove the carpet below the concrete slabs and try thin cork as a "glider & protector".
LINN Skeets (they do look interesting on the LINN homepage, though) are not in stock at a dealer nearby- I'd have to order them via Germany. As they are not a very expensive item (approx. Sfr 100.- for 8) I may just be brave and try them anyway.
Should I hear any changes, that are more than bare "psycho-acoustics" I'll post them here.
Urs
I have just had to cope with the same issue as you. I am currently using small coins under the spikes. Seems to work fine and a lot cheaper than Linn Skeet.
I find that the weight of the speakers is enough to keep the coins tightly coupled to the floor, but still allows the speakers to be moved, slowly and carefully, without dislodging the coins.
Worth a try as it doesn't cost anything (unless you use large value coins), I used 5 pence peices, same under the equipment racks.
Simon
I use the Linn skeets. Some people here say the screw up their sound, and I believe them, but on my laminate floor the speakers certainly sound better with the skeets. The reason may be that once the laminate boards are pierced, the spikes hit the rather cheap material underneath the top coat, which is too soft to support the speakers properly.
Perhaps you can check the stores to see if there are similar products by other manufacturers – I doubt the differences would be that big.
Thomas
Plus,at the moment it's too bloody cold !
(but summer is (hopefully) just around the corner)
...Wonder if the fact that I usually wear both Feet in my Mouth would count for anything ?
If you do manage to get up in that neck of the woods,then please let me know (preferably with as much advanced warning as possible)
Chris
