Without PIC
Posted by: Lightkeeper on 04 April 2003
Chapchachos !
My CD5 say P108, which means that I don't have upgraded PIC, it's almost new (november 02'). I am interesting what really happens when you press play and want to listen protected cd on Naim cd player with previous version of software or whatever that is?
Thanks,
Ozren
Posted on: 04 April 2003 by Lightkeeper
I think that this should be replaced,
Posted on: 04 April 2003 by Frank Abela
Ozren
P108 has no copy protection fix. The PIC update with the copy protection fix in it is P109. You should really let your dealer do the modification for you, unless there is no dealer in Zagreb of course!
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Frank !
I know that P108 is not fixed and I should upgrade to P109 for playing protected discs without problem, but I still don't know what will happened if I want to play protected cd in CD5.
(Still don't have one).
Yes there is a dealer here in Zagreb, which is not Naim only dealer because he sell Mission/Cyrus, but you can order any black box you want and must wait aproximatelly 4-6 months. Of course, any demonstration of Naim equipment is impossible, just pay and wait... (said, isn't it).
Frank, I will do it myself. It is easier to exchange that piece than soldering a cable to connector, believe me. I was do that many times with computer components. Wink
Ozren
Posted on: 04 April 2003 by greeny
Ozren
The symptom varies a bit depending on the type of copy control I think. I have a CDX without the upgrade. The one CD I have had a problem with (CAVE IN - ANTENNA) experienced about 1-2 seconds of jumpy replay a few seconds into each track, very annoying but still listenable.
Greeny !
Thanks,
Ozren
