Re-boot N-vi
Posted by: Brett 10 on 28 January 2007
Help -
How do I re-boot the system after 6 months of perfect playing my N-vi has thrown a spaner, I (stupidly) turned it off at the power sypply blast night and this am it will not wake up?
Regrads
Brett
Regrads
Brett
Posted on: 28 January 2007 by Former member
Turn it off and on at the back of the n/vi a few times leave it a few mins in between. This should wake it up.munch
Posted on: 28 January 2007 by Brett 10
Munch
Thanks for the reply but does not seem to help, it powers up but then seems to freeze.
The power bar window appears, the next window appears, input and mode, and then it freezes. It indicates that Midnight Mode is also selected but I don't think I did this, don't know if that means anything (probably not?)
The power supply to the nVi has not been turn off for a couple of months and has worked well until today.
I was under the impression the software can be re-booted in some way.
Brett
Brett
Posted on: 28 January 2007 by john R1
brett 10, have turned my n-vi off quite a few occations its always come back on no trouble, in fact often have to re-boot mine to sort out the little hic-cups it throws at me.
John
Thanks for the info, it powers up and then it seems to hang after the power bar window. It seems to get stuck and completely freezes.
Brett
Brett
Posted on: 28 January 2007 by Duncan Fullerton
S'funny but mine threw a wobbler tonight as well.
Aside from the normal daily reboots to sort out the SPDIF input, I got the rarer "help me! Please turn me off" message. Tragically when it came back the DAB/FM module was totally fucked. These n-Vi's really are piles of poo at times.
I'm waiting patiently for a code drop for the SPDIF issues - any news on this AV or Adam? Mind you if the DAB is toast then the replacement box will be my fifth. Maybe that will have working firmware? Quality control indeed ...
Duncan
Duncan
Posted on: 28 January 2007 by nap-ster
If the NaimNet has the same firmware issues............
Posted on: 28 January 2007 by AV@naim
Brett10 can you mail info@naim-audio.com please.
Av
Av
Posted on: 29 January 2007 by Duncan Fullerton
So no news on the new firmware update then, AV? Does this mean a) there is a delay in the release or b) you missed my question about two inches up the page?quote:Originally posted by AV@naim:
Av
Duncan
Posted on: 29 January 2007 by AV@naim
quote:Originally posted by Duncan Fullerton:So no news on the new firmware update then, AV? Does this mean a) there is a delay in the release or b) you missed my question about two inches up the page?quote:Originally posted by AV@naim:
Av
Duncan
I am awaiting more information on when it is to be released.
Ta! Fingers crossed that it is soonish!
Is there some deep reset I can try on my DAB? It is playing one station only and failing to find any others on a scan. Text display/details of the one station are not showing. FM set at 000.00 MHz and will only tune up to 000.10 MHz. No options can be chosen via the FM menu.
Duncan
Duncan
Posted on: 29 January 2007 by Avalin
That sounds very similar to the problem I encountered with my brand new Nvi. There was a single weak station (Radio 2) that was being received on DAB and Fm and that my dealer had tried to tune into when he was testing the unit. It could not find any other stations upon rescanning nor would it accept direct input and it showed 0 kbts signal strength, despite the prescence of an external multi element aerial. Ditto on FM with 0% sigmnal and no ability to scan, store or find any other stations. Maybe my problem was not so isolated?
Duncan,
see email
AV
see email
AV
