aerials
Posted by: anselm on 23 October 2003
i am getting back my tuner from a friend it is a nad 4225 i think, i live in a rented house so a quality external FM aerial is a no-no, so any suggestions on a good indoor aerial that will perform adequately?
thanks
current system 3.5/112/180/A5 epos es22
Anselm
all art is contemporary; it is the way we look at it that changes...
Posted on: 23 October 2003 by Geofiz
Anselm,
Somewhere on the forum is another thread dealing with this topic, but ....
If a simple wire dipole will not do, I can recommend the Magnum Dynalab ST-2 omni-directional indoor/outdoor antenna (~$99US) and the SR-100 ($30US MSRP) silver ribbon tuneable antenna. I have both and they work very well.
Posted on: 23 October 2003 by Phil Barry
Audio mag of Jan or March, 1990 had an article on homebrew's. The H-shaped one was great - I usedit for several years. The MD ST2 is much better looking, but not better performing.
Regards.
Phil
Posted on: 24 October 2003 by Roy T
Anselm,
this may be of use Decent Reception from indoor antenna.
Roy
Posted on: 25 October 2003 by Dev B
In my old flat I used the circular bit of a Ron Smith Galaxy 17 and it worked really well. I now use the whole Galaxy 17 on my NAT01 and I would say anything else than a Galaxy 17 or GAlaxy 0 is a massive compromise and you are probably better of with DAB or a Sky Digibox but done right a NAt01 is the business and can beat any source
Posted on: 25 October 2003 by prowla
Is a TV aerial OK for radio?
Paul Rowlands
Posted on: 25 October 2003 by custard
I use a TV aerial and find it a vast improvement over the T shaped freebie that you get to start you off with.
