New blood
Posted by: Rockingdoc on 10 July 2001
They are still reeling with the price of true audio, and I can't persuade them beyond the cost of absolute entry level Naim.
I find it difficult to fairly assess bottom end Naim, but they won't trust their own ears and want an "expert" opinion.
They are close friends so I will have to live with the results of the decision for a long time. I doubt if they will get into upgrading.
Should it be a Naim system at all, and what about the speakers?
Rocking, how much do they want to spend? How about used? I just sold an Arcam Alpha CD/32.5/110/Rega EL8 system for £450 including NAC A4 cables. When I installed it I realised just how well it made music. In fact, in some ways, I prefered it to my current system.
Anyway bangs for bucks.....
CD
Used
CD 3, CD3.5
New
Rega Planet
Arcam Alpha 7
Around the £450 -£550 mark. I'm wary of used CD players unless you trust the seller to make good if it fails soon after you buy it! Naim sellers usually are....
Amps
Used 32.5/110 or even a 90. With MM or MC boards for the Rega. Don't go anywhere else! Ok. maybe a 45 or 62.
Around £300-350
New? never bought a new amp!
Speakers
I like the Regas (El8, Kytes)
Around £80 to £150
I'm sure others have speaker suggestions!
Stephen
The real problem is that I am going to be forced to listen to this system at least one evening a week for the rest of my life!
Stephen
Regards Bruce
Used Cd 3 / New Rega Planet /CD 3.5 if you are lucky (like me!) £450
Used 32.5/110 350
New Intro IIs 800
OK, £100 over, but what a bloody system!
You could probably get all this from a dealers with a warranty & ex dem speakers if you are lucky. Why not call a couple of dealers & see what they have in stock? If you can persuade your friends to go used on the amps at least, they will be getting a Much better system than for new.
Stephen
1k-1.5k. Not much to buy a new system with. For that kind of money you're probably best taking them to Richer Sounds.
Sadly, in recent years, Hi-Fi has jumped in price. However, I could recommend trying out a Creek CD Player and Creek Amplifier system. Maybe one of the cheaper Exposure components would suit too. These can be compared at Grahams Hi-Fi.
Loudspeakers? Tannoy tend to do some of the best cheaper models - sadly Royd have priced themselves out of your friends' reach.
Audionote are also about to do a nice small speaker at about £200.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Some friends of mine are ready to buy their first real HiFi. They own a Rega3 only, so are looking for a CD player amp and speakers.
If buying new I would go for the new Exposure CD player (700ish), a Densen Beat integrated amp at 600 and probably a pair of Linn Kan III assuming they sound similar to the Tukan, or some little Royds.
If they could be persuaded second hand my choice would be for a CD2 (750 - 900), Nait 2 (200) Kan I or II (150 - 250).
Tony.
cheers
Nigel
Not only that, but it has loads of 2's - that's gotta be good for summat. ![]()
Rico - all your base are belong to us.
And if funs are really tight, they could even try out a Marantz CD-63KI first,and upgrade at a later date when funds allow.
I tried the CD63KI/Nait-2 with some Monitor Audio Studio-2. The system costed about 1000,- UKP and sounded great for that kinda money.
but ofcourse a CD2/Nait2/Kan-2's would be a very nice start! or a s/h CD-3.5 with flatcap
(see my story/pictures at www.hifi.nl and then click at "De set van de week"
o,..forgot..it's in Dutch! sorry.
See Y'all
Greetings,
Alco.
Really good friends of ours have a Technics system. YES - Technics! plus B&W speakers.
The speakers cost £800 and the CD/Tape/Amp under £700. He runs the system bi-wired and has it all neatly stacked in one of those glass-fronted cabinets with all the wires neatly dressed out of sight down the back.
Sounds absolutely bl***y marvellous, always. I often have to put mine on as soon as I get back, just to proove to myself that mine really is slightly better. Even then I am still impressed with theirs !!
If you think this approach might help I'll get exact model numbers for you
Don
Chris
You can also tell them that no one has ever bought a used naim Amp and regretted it - and they can sell it for the same price, usually.
stephen
I'll still be dragged along to the dem. to look wise.
I went with my brother-in-law to choose a "starter" system a little while ago. It was a brilliant experience.
He chose a Rega Planar 3 / Nait 2 (ex dem) / Royd Minstrels / Rotel CD Player (can't remember the model number).
It is a great system and he chose it with minimal input from me.
Chris ![]()
Planet 498 GBP
Brio 298 GBP
Alyas 300 GBP
Rega shelf for turntable 38 GBP
3 shelf Quadraspire table c230 GBP
Chord Silver Siren interconnect 70 GBP - I know this works well in this particular system.
Naim NacA5 cable - depends on required length, say 100 GBP including plugs.
I'm 4 quid under budget!
Alternatively:
The Densen Beat B100 integrated (700 GBP BTW, not 600 Tony
It's always a nice day for it, have a good one ![]()
Steve
Steve
