AV product firmware update information 2011
Posted by: AV@naim on 27 October 2008
Current AV product (AV2, DVD5 and n-Vi) revisions are shown below:-
(Revised 27th October 2008)
Note:- Please contact your dealer concerning applying any updates.
AV2:- Obtained by pressing and holding OSD button on remote control for 5 seconds. Front panel will display the below string(s) sequentially for latest firmware
AVC0107 (naim PIC revision)
F658 (control DSP revision)
AV2 Firmware status: Last updated 1st June 06
Note:-
-AV2P209, AVC0101 -> AVC0106 can be updated via RS232 by your dealer
-AV2P1xx and AV2P208 cannot be updated via RS232 and will require a new PIC chip to be fitted
(This has to be done either by your dealer or at Naim HQ).
(F413 and F421 DSP firmware should be updated to F658 if used in conjunction with DVD5)
DVD5:- Obtained by pressing and holding PROG button on remote control for 5 seconds. Front panel will display the below string(s) sequentially for latest firmware
C0105 (PIC revision)
M0007 (Comms revision)
C0189 (upper bytes of CHEERS revision)
01002 (lower bytes of CHEERS revision)
DVD5 firmware status: Last updated 27 October 20012 (available as disc based update via your dealer)
n-Vi:- Obtained by pressing and holding PROG button on remote control for 5 seconds. Front panel will display one of the below sets of strings for latest firmware. (See below for information on the two firmware releases)
PIC c02-15
CHEERS 000.189.005.006
OR
PIC c02-16
CHEERS 000.189.005.003
NOTE: If the n-Vi has the latest display fitted the software will be
PIC c02-21
OR
PIC c02-22
Firmware status:- Last updated 27 October 2008 (available as disc based update via your dealer)
Important information concerning n-Vi code versions: 0.189.5.6/DVc02-15 and c02-21/189.005.006 also 0.189.5.3/DVc02-16 and c02-22/189.005.003
To accomodate for a material dependant variance concerning SPDIF latency, Naim have released two versions of n-Vi code. As per 27th October 2008, new builds of n-Vi will be delivered running 0.189.5.6/DVc02-15 code. This has, amongst other things, fixes for lip-sync/latency issues at the expense of longer SPDIF lock-on times (material dependant).
We would recommend using the current production code if you are an avid movie fan, but if you are mainly watching SKY and regular TV and are experiencing problems the longer SPDIF lock-on times, then we would suggest you speak with your dealer, who can supply you with 0.189.5.3/DVc02-16 and DVc2-22. Note:- this has relatively fast SPDIF lock on times, but increased system latency which could at times contribute to lipsync problems.
